wheel offset??
Old Sep 19, 2010 | 07:16 PM
g_mike's Avatar
g_mike is on a distinguished road
Default wheel offset??
are zr2 wheels a different offset or is it the axles that are at a different spacing?
i want to have mine the same width as a zr2 and im probably going aftermarket with the rims so get that spacing that i want.
so to have the lip of the rim flush with the body what offset would i need?
Old Sep 19, 2010 | 07:45 PM
AJBert's Avatar
ZR2's have the same backspacing as non-Z's. The track width is about 4" wider on ZR2's, so if you want the same width as a ZR2 get some rims with 4" of backspacing.
Though, you may end up with some rubbing issues up front.
Old Sep 19, 2010 | 07:48 PM
g_mike's Avatar
thank you for the reply.
ok then here is a question...
i read in another post that the 2wd is 1.5 backspacing different.
but i also read in another thread that someone put 2wd rims on his 4x4 and they stuck out even further.
Old Sep 20, 2010 | 09:03 AM
AJBert's Avatar
Correct, with 2wd wheels they will stick out 1.5" more than the 4wd rims.
jayj99jimmy
Dec 12, 2011 11:55 AM
Appalachian American
Tires and Wheels
Jul 4, 2011 09:10 AM
grimace007
Jul 26, 2010 05:33 PM
sporty_drew
Tires and Wheels
Aug 9, 2009 11:47 PM
9blzr9
Dec 8, 2005 05:33 PM
