Wheel Spacers
Old Oct 19, 2014 | 07:08 PM
madmaxxed's Avatar
madmaxxed is on a distinguished road
Default Wheel Spacers
Hello all. I recently installed some spacers on my blazer. I also run some on my 2010 MINI Cooper S but the mini uses bolts rather than the lugs and nuts. I'm questioning whether I should've used the stock lug nuts on the spacer lugs to hold the wheel or use the stock lug nuts to hold the spacer to the hub. Any thoughts? Thanks.
Old Oct 19, 2014 | 08:45 PM
rexmburns's Avatar
Super Moderator
I ran the spacer nuts on the spacer and factory/aftermarket on the wheels. I had aftermarket locking nuts with my wheels so they wouldn't work on the spacers. I believe the spacers nuts were also the same taper as the spacer so I would have ran them that way even with factory lug nuts. I put a little locktite on the spacer nuts for good measure as well.
Old Oct 19, 2014 | 08:48 PM
madmaxxed's Avatar
Thank you Rex. I will swap them out at some point.
Old Oct 21, 2014 | 12:46 PM
HARDTRAILZ's Avatar
HARDTRAILZ is on a distinguished road
2nd...Spacer nuts on the stock studs to hold spacer on. Then whatever lug nuts you normally use to hold the wheels on normally can be used on the studs built into the spacers.
I have ran adapters for 5 years and had several different lug nut styles to hold the wheels on but always used the spacer nuts to hold the spacers on.
twistedmetal
Feb 8, 2018 07:04 PM
calee4nyaboy
Nov 20, 2009 11:48 PM
Bosaliniee
Suspension Tech
Jan 28, 2007 10:23 PM
nails5240
Tires and Wheels
Jun 14, 2006 12:38 AM
quontush
Apr 21, 2006 08:27 PM
