will 2004 gto wheels fit my 97 2dr ls w/ 3/4 drop?
Old 03-26-2009 | 09:28 PM
j_snake's Avatar
j_snake is on a distinguished road
Default will 2004 gto wheels fit my 97 2dr ls w/ 3/4 drop?
Old 03-27-2009 | 12:24 AM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
the have the same bolt pattern itll just depend on the backspacing.
Old 03-27-2009 | 03:02 AM
Iced696's Avatar
Iced696 is on a distinguished road
The GTO wheels are very close to the same specs as Vette wheels and you'll find that adapter/spacers will likely be needed. Don't skimp on these as you get what you pay for when it comes to the adapters. That is not to say you need to spend $150 each for them and believe me, I have seen people try to charge this. Shop around and find a good billet spacer/adapter. I considered the Goat wheels and even thought about a set of Crossfire wheels before settling on a set of Vette wheels. I did some research for you and found a chart on one of the GTO forums. Everything you should need is listed below and anybody who makes the adapters who is worth dealing with will know which direction to steer you in.
WIDTH..........OFFSET............WIDTH OF TIRE
7.0...............+26/+65.............215/225/235
7.5...............+33/+61.............215/225/235/ 245
8.0...............+39/+55..............225/235/245
8.5..............+45/+48..............235/245/255
9.0.(MAX).........+48................245/255
REAR ONLY
8.0................+36/+65.............245/255
8.5................+42/+65...............245/255
9.0.................+48/+65...............255/265/ 275
9.5................+55/+64...............265/275/2 85
MTopper
07-12-2011 01:19 AM
DKSDAD
Shows & Clubs
06-20-2010 01:40 AM
DKSDAD
06-10-2010 10:21 PM
wlorton
03-08-2010 12:45 AM
lastcoupe
Street N Strip
23
05-06-2008 08:39 PM
