Will 275/40/20 tire rub?
Old Mar 31, 2008 | 04:54 PM
juicy_jay_510's Avatar
juicy_jay_510 is an unknown quantity at this point
Default Will 275/40/20 tire rub?
I want to get 275/40/20 tiresall around and i was wondering if they will rub, ill probably do a 2/3drop later, will i rub with the drop?
Thanks
if youhave pics of a blazer or s10 with this size tire can u post them, soi can see how it looks.
Old Mar 31, 2008 | 05:16 PM
WolfPack's Avatar
Default RE: Will 275/40/20 tire rub?
Well...lets say this..I've got 265/70/15s, and I rubbed like crazy at stock height. This was with a 4.5' backspaced rim. I would imagine your 20' is a similar backspacing, but if you have the stock 6' of backspacing, you'll just rub frame. I had to trim the back of the wheel well, and then lifted 1.25' in the front and 1.5' in the back and I still rub at full lock on the wheel well cover. A bit more trimming would take care of it, but it's fine for most daily driving.
After a drop I would say you won't be able to barely turn. When I had stock everything (cept for the rims) I could only turn 1/4 turn of the steering wheel to each side before catching fender horribly.
Old Apr 1, 2008 | 04:53 AM
thegr81's Avatar
With running a 20 inch rim the preffered tire size if planning a drop latr would be 215/40r20 if you desire that cushion of a 40 series do you plan on eventually bagging your blazer after the drop in the future?? If you do then you might as well get 215/35r20 to avoid excessive cutting and also keep your ac and heat!!!
Old Apr 1, 2008 | 09:21 AM
WolfPack's Avatar
Haha oh wow...didn't realize dropping and bagging was so involved! I suppose slamming it does stuff the wheel all the way up into the well...looks sexy but I have no idea where the wheel goes!!
Old Apr 1, 2008 | 12:22 PM
nj4x4blaze's Avatar
Mmmmmmm bagged blazers on 20's....
Old Apr 1, 2008 | 12:27 PM
WolfPack's Avatar
Can those actually drive while down on the frame? I can't imagine they turn very gracefully..
Old Apr 1, 2008 | 12:30 PM
nj4x4blaze's Avatar
They can drive straight but no they can't turn unless they dont want their fenders anymore. So they have to air up the trucks high enough so the wheels will clear without rubbing on the fenders.
Old Apr 1, 2008 | 05:18 PM
so 275s will rub, what about 245 or 255 40 20s, i want a wide tire. Ive seen a blue 4 door with 245 on the front and 275 on the back and he had a 5/6 drop.
Old Apr 2, 2008 | 05:58 PM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
my blazer is at factory xtreme hight, and i have a 245/35/r20 and i have room to lower it 2' and it would fit fine, pix in my gallery
2000BlackBeauty
Tires and Wheels
Oct 10, 2013 09:40 AM
itsmejonnyb
Tires and Wheels
Feb 4, 2011 09:17 PM
midnightbluS10
Tires and Wheels
Apr 17, 2010 12:12 PM
DKSDAD
Tires and Wheels
Sep 26, 2009 08:40 PM
GABlazer92
Tires and Wheels
Jan 24, 2008 09:38 PM
