will these fit
will these fit my 2nd gen 2005 blazer? http://jacksonville.craigslist.org/pts/577402506.html
whould they even look good tho cant really get a good image in my head. but i have a 2 door pewter blazer so if anyone is good with photoshop if you can photochop. also what other stock rims will fit a 2nd gen blazer i heard that the old comaro rims will fit.
thanks.
thanks.
I'm not entirely convinced how good they will look on the blazer..maybe alright on a 1st gen, but there's not sharp lines on our blazers to match those wheels..
Definitely get that photoshopped before dropping 500 unless you know you love em!
most any 5 on 4 3/4 steel or aluminum wheel will fit on a 1st or 2nd gen blazer the only problem you run into is as said there are no sharp lines to accenuate the wheels also meny of the older steel wheel that look good are 14" wheels which depending on your treds will look " dinky" on the blazer.
the elcomino wheels are 14" and to fill your wheel wells you will have to run an oversized tire or lower your ride for it to look right, also 500$ for a set of 14' steel wheels in my opinion is a little expensive.
a set of older wheels that look good on a 2nd gen blazer are the aluminum rs and z28 comaro5 spoke wheels 85? - 92 these are 16" wheels and with the right rubber look very good on the 2nd gen http://customwheel.com/custom_wheels/images/irocz.jpg
south side
south side
thanks, yea i wasint sure i seen them on 1st gens but never 2nd so idk about what it would look like, but il check up on the other rims. its just when i get tires and a lift i dont want to have the basic s10 blazer/pickup rims. whats a good site that has some good rims for cheap, i know summit has some good prices but are there anymore?
Just like any other shop, they'll have higher prices and some lower prices. They have the advantage of being a national chain with a deeper stock, so they're always worth checking out. Something like Pro Comp rims, you kinda know what the retail price should be, so you can just use it to compare.
ok well i found some decent rims that i kinda like but before i make a deal or anything i want to get a picture tho on how they look photoshoped.
but the advise tho the blazer picture is not mine and i found it on cardomain, google doesint have anypictures of 2dr blazer in gold. so this picture is not my blazer but it looks just like it just without the rack.
