will they fit??...
20"s may be pushing it a little. but the 18's should fit. i would try to match the overall hight of your current tires to the now ones. if you have some rubbing now go a little smaller. heres a link to play around with possible tire sizes that would work.
http://www.1010tires.com/TireSizeCalculator.asp
enter your current size and then try different sizes until you get a size that is the same or close
hope this helps
hope this helps
