Will They fit??
Old Jul 26, 2009 | 07:57 PM
duvall45's Avatar
duvall45 is on a distinguished road
Default Will They fit??
I picked up some Ultra wheels claws 16x8 with a +25 offset and some 255/70/16 tires to put on them. My question is will they fit on a standard 4dr 4wd? Everything I have read said that a 30in tire will fit with no rubbing. According to a tire calculator these tires should be 30.05" diameter and 10.03" wide. Also thinking of adjusting torsion bars to lift a little and help them clear. How safe is this? It seems like it would put a lot of stress on the front end.
Thanks
Attached Thumbnails Will They fit??-3kf3mf3l8zzzzzzzzz96j3a555a4097a812fa.jpg
Old Jul 26, 2009 | 08:38 PM
8" wide with a +25mm (~1") offset would make for about 5" of backspacing. This is fairly close to the factory 6" (closer than most rims). Those tires should not have too much trouble. The problem may be while steering and it would likely be at the firewall. Factory offset rims should not have problems with a 30x10 wheel. Most run 30x9.5-15's on the factory rims.
Old Jul 26, 2009 | 08:45 PM
bandidolenny's Avatar
I believe that you will be able to get away with this. If it does rub while turning, you could always crank the t-bars a bit or do a body lift.
Old Jul 26, 2009 | 08:48 PM
duvall45's Avatar
I didn't realize it was 6" on a 4wd. Is there anything I can do like spacers or lift?
Old Jul 26, 2009 | 08:50 PM
Spacers will make things worse not better.
Old Jul 26, 2009 | 08:51 PM
duvall45's Avatar
sorry 2nd reply was posted while I was responding. How far can I go with t bar and not kill my front end?
Old Jul 26, 2009 | 08:55 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
1.5" seems to be a happy medium, but any tbar crank will increase wear and tear.
Old Jul 26, 2009 | 09:17 PM
Oh ok, you mean lift spacers... Nope, just adjust the t-bars up for about an inch of free lift in the front... I would not even mess with the rear (I don't care for the nose down look).
Old Jul 26, 2009 | 09:28 PM
duvall45's Avatar
I like the fender flares on your truck. Where did you get them? I have searched for Pace flares but don't see them for 4dr blazers. I have seen that there is different models (ie no lip, heavy duty, etc) just wondering which ones you have and any pros and cons.
860gmc
Tires and Wheels
Jul 22, 2007 09:31 AM
drperry
Tires and Wheels
Apr 25, 2007 09:13 PM
JST4SHO
Tires and Wheels
Apr 13, 2007 10:26 AM
FImports
Tires and Wheels
Dec 9, 2006 12:12 AM
chevy4life
Tires and Wheels
Oct 31, 2005 09:59 AM
