Zr2 spare tire lock(i'm an idiot).
Old May 1, 2008 | 05:39 PM
Smoked's Avatar
Smoked is an unknown quantity at this point
Default Zr2 spare tire lock(i'm an idiot).
Howdy... first time i've tried removing the spare...i find a shiny silver lock on one of the lugs on the spare. It has a key hole just like one of the door locks but it just spins around in either direction. I was only given one key with this car...is it the main ignition key? What do i do? I feel so retarded
Old May 1, 2008 | 06:06 PM
willjones's Avatar
Default RE: Zr2 spare tire lock(i'm an idiot).
The way you take it off, is just put your key in and turn it clock wise and as you turn it pull it straight back and off. All it is is a lock pin release.
Old May 1, 2008 | 06:16 PM
Smoked's Avatar
Thanks but that's not working. Is the whole things supposed to spin around? Or does an inner part spin inside the outer part? I put the key in and turn clockwise and it will keep spinning endlessly... pulling out does nothing
ORIGINAL: willjones
Old May 1, 2008 | 06:54 PM
willjones's Avatar
You have to hold it while you turn the key. The key should only turn a little bit. I just went and did it on mine like 5 seconds ago.
Old May 1, 2008 | 06:58 PM
Smoked's Avatar
So it's supposed to turn around all the way... but the middle part with the key should turn inside the whole unit?
ORIGINAL: willjones
Old May 1, 2008 | 07:04 PM
willjones's Avatar
The outside shell doesn't need to turn at all, only the center.
Old May 1, 2008 | 07:31 PM
Hanr3's Avatar
die grinder, cut off wheel, or drill bits.
Old May 1, 2008 | 09:57 PM
Smoked's Avatar
Sorry I wasn't clear...i mean it's normal that it turns all the way around in general...not for the purposes of opening it I sprayed some wd40 in there...will try again in the morning. Man nothing's gone right with this truck since i've got it...all the stupid little stuff that can go wrong has
ORIGINAL: willjones
Old May 2, 2008 | 08:40 AM
Smoked's Avatar
Okay, even after soaking it with wd40 and leaving it overnight the key wont' budge. Am i seriously going to have to drill this thing to get my spare off?
Old May 2, 2008 | 10:37 AM
Zed's Avatar
Zed
Zed is an unknown quantity at this point
I bet if you just give it one whack with a hammer it will come right off as there isn't much holding it on ...
Just stick the key straight in and pull hard on the chrome piece , if that doesn't work take a screw driver and put it in the key hole and give it a whack ?
Zed
