TrailBlazer GMT360/GMT370 (2002-2009) Tech Have a 2002-2009 Trailblazer, Envoy, Bravada or Rainier? Post your general tech questions here.
2004 Trailblazer blower don't work
Old Oct 24, 2007 | 05:45 PM
candjman2's Avatar
candjman2 is an unknown quantity at this point
Default 2004 Trailblazer blower don't work
I have a 2004 TrailblazerLS in which the heater blower dont blow any air out. At first it only worked if you set it on 3 or higher, then it only worked if it was set on 5 and now it doesn't work at all. I don't know what to check or where to find what I need to check. Can anyone help me?
Old Oct 24, 2007 | 05:57 PM
Default RE: 2004 Trailblazer blower don't work
*Moving to GMT 360/370 Tech*
This is commonly caused by a failed blower motor resistor pack.
To replace it, you will need to remove the hush panel under the passenger side dash. The resistor pack will be located next to the blower motor and held on by 2 7/32" screws. Next, open your glove box and empty it. Then lift up on the stop arm on the driver's side top of the glove box and swing the glove box down and out of the way. This will give you access to the electrical connector for the resistor pack. Unplug the connector.
Reassemble reverse of disassembly with the replacement resistor pack.
project85
Jan 15, 2015 03:23 PM
Charbear
Sep 18, 2011 12:40 PM
MTopper
Jul 12, 2011 12:19 AM
88s10Blazer
Lifting Tech
34
Oct 17, 2010 02:50 PM
surferbarnes
Suspension Tech
Sep 27, 2006 01:27 PM
