TrailBlazer GMT360/GMT370 (2002-2009) Tech Have a 2002-2009 Trailblazer, Envoy, Bravada or Rainier? Post your general tech questions here.
Brake lights
Old Dec 21, 2010 | 08:07 PM
qwert's Avatar
qwert is on a distinguished road
Default Brake lights
Could use some help diagnosing a problem. My brake lights won't work, although the same bulbs come on with turn signals and hazards. Center brake light also works. Checked stop lamp fuse and that is okay. This is a 2004 Trailblazer. Thanks!
Old Dec 21, 2010 | 08:19 PM
The brake light and the turn signals / hazards use different bulbs in the back of the GMT360 trucks.
Do you have power to the stop lamp pin in the trailer plug?
Attached Thumbnails Brake lights-04_gmt360_extlts_1of2.gif   Brake lights-04_gmt360_extlts_2of2.gif
Old Dec 21, 2010 | 08:32 PM
qwert's Avatar
Not sure what the pin is, how do I check this?
Old Dec 22, 2010 | 06:34 AM
Google '7 pin trailer pinout' and you will find the answer...
Use a test light to test for power.
Old Dec 22, 2010 | 10:12 AM
qwert's Avatar
I didn't have a test lamp, so I hooked up to the trailer and the Brake lights work. Does that answer your question? If not do I just touch the test lamp to the stop light pin?
Old Dec 22, 2010 | 10:16 AM
Sorry, no that doesn't actually help... I read the schematic too quickly and mis-read it. The trailer brake lights are just an interrupted turn signal.
If your VEH STOP fuse (#34 15A) located under the driver side rear seat is not blown, then the next step would be to check the wiring back at the tail light housings themselves. You need to check for +12V at Pin A of the tail lamp circuit board wiring connector.
Old Dec 22, 2010 | 10:31 AM
qwert's Avatar
The fuse is good. I will look into the tail light housings. Is it possibly the brake switch even if the center brake light works?
Old Dec 22, 2010 | 10:35 AM
As the schematic shows, the brake switch provides power to the CHMSL, the lower brake lamps, as well as the trailer brake lamp circuit so the switch itself is working.
edavison
Dec 20, 2010 09:55 PM
step66
Oct 14, 2010 04:52 PM
SCBlazer96
Apr 16, 2010 08:39 PM
dashyman
Jan 12, 2007 11:28 AM
rryker
Apr 25, 2006 04:14 PM
