TrailBlazer GMT360/GMT370 (2002-2009) Tech Have a 2002-2009 Trailblazer, Envoy, Bravada or Rainier? Post your general tech questions here.
No Brake Fluid Right Rear 04 Trailblazer
Old Oct 24, 2020 | 10:18 AM
A1 Handyy's Avatar
A1 Handyy is on a distinguished road
Default No Brake Fluid Right Rear 04 Trailblazer
I just purchased an 04 Trailblazer LT. There were no brakes on the truck and upon further inspection, it was discovered that the right rear line had been cut. Also, the booster was disconnected from the pedal. I replaced the booster and the broken brake line but still not much fluid at the right rear caliper. I replaced the caliper and the master cylinder as well and I have fluid coming from the master cylinder but still only very little fluid at the rear cylinder. I have inspected the line from the master cylinder to the caliper and I cannot find any damage or blockage. Any ideas where the problem may be?
Old Oct 24, 2020 | 10:19 AM
A1 Handyy's Avatar
This problem is with the left rear not right rear?
Old Oct 24, 2020 | 12:51 PM
On my 99 blazer, I had a metal bracket around a rubber hose swell from rust, which in the end caused my caliper to constantly fail.
different vehicle and setup, but could be a possibility if you have brackets holding rubber lines...
Micdav8579
Mar 13, 2020 10:29 AM
RiverDog
Jul 30, 2019 07:15 AM
Robby Orr
Apr 29, 2018 06:56 PM
Spree
13
Aug 30, 2015 10:46 AM
97Blazer15
Apr 26, 2007 07:21 PM
