1990 Blazer differential compatibility
Old 11-29-2015, 02:21 PM
surreybrad's Avatar
surreybrad will become famous soon enough
Default 1990 Blazer differential compatibility
I have a 1990 Blazer with a Dana 12 bolt rear. I want to install a complete rear diff with disc brakes and equally strong gears from a newer truck at the wreckers. Can anyone tell me where I can find a list of what will bolt on to my 1990 or with the least amount of conversion work. Thanks
Old 11-29-2015, 06:30 PM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
4wd or 2wd?
Old 11-29-2015, 07:57 PM
surreybrad's Avatar
It's 4wd. It originally had a 10 bolt I think but the previous owner switched it to a 12 bolt from an earlier model.
Old 11-29-2015, 10:54 PM
richphotos's Avatar
You can get a rear diff out of a second gen that has disc brakes. If you google that you will find a lot of info about it.
You will obviously need to make sure it matches your current gear ratio.
Just make sure you do not get a rear diff out of a zr2 as they are wider.
Old 11-29-2015, 11:09 PM
surreybrad's Avatar
Ironically, I have a 1998 ZR2 and discovered the size difference on a hunch but forgot to consider the special aspects of the ZR2. This is good news because the one thing there isn't a shortage of around here are 2nd gen Blazers. Also, thanks for the heads up about the ratio and this timely response to my request for assistance.
ScarletIce
07-10-2014 07:08 PM
Drew4711
10-06-2012 12:47 PM
deadpool
11-10-2009 01:45 PM
98BlazerLT4x4
03-04-2008 06:00 PM
EMTBlazer
12-03-2006 07:13 PM
Quick Reply: 1990 Blazer differential compatibility
