89 s10 blazer tips on changing pads?
Old 07-14-2011, 08:55 PM
sweezo's Avatar
sweezo is on a distinguished road
Default 89 s10 blazer tips on changing pads?
i have new pads for the truck, im goin to replace them this weekend. anyone have any tips?
Old 07-14-2011, 10:51 PM
wazzledoozle's Avatar
wazzledoozle is on a distinguished road
Get some wheel bearing/brake grease, a 6" mininum c-clamp, a 13mm ( I think) gm wheel caliper hex socket, and some brake fluid. Grease up the caliper bolts and scrape away any dirt/rust from the holes they travel through for smooth, unsticking brake operation. Also suggested by the chiltons manual is to get a turkey baster to remove some brake fluid from the master cylinder reservoir before bottoming the caliper piston, have the reservoir cap sitting at an angle on the reservoir while bottoming the piston so the pressure can equalize and dust wont settle in the brake fluid.
If you find you have pulsing brakes after putting new pads on, you're rotors are warped and need to be replaced or resurfaced. While the pads are off, inspect the caliper piston seal for any leaking brake fluid or other obvious damage.
Oh, and make sure you torque the lug nuts in a star pattern, with a torque wrench. Otherwise you may warp the rotors and cause headaches further on. 73 ft/lbs for steel and 90 for aluminum
Old 07-16-2011, 03:35 PM
ProjectICE's Avatar
ProjectICE is on a distinguished road
while you have off everything....you minds well take off your rotor hub and repack the bearings with grease....beleive it or not it adds for a nicer ride.....
Old 07-16-2011, 10:41 PM
maddie's dad's Avatar
maddie's dad is on a distinguished road
You never mentioned if your truck was a 4x4 or 2wd. Makes a difference in servicing the wheel bearings. On the 4x4 hubs, they are sealed and no service is required or possible. ProjectIce is right about packing the wheel bearings for a 2wd though. It should be done everytime you replace your brake pads.
Old 07-18-2011, 01:31 PM
sweezo's Avatar
its is a 4x4. i am trying to locate the right size hex tool so i can get the calipers off. its a simple job, its just pads but i need that tool. i will try and find a bigger set i only have smaller ones.
Old 07-19-2011, 02:51 AM
I had to get a GM-specific brake caliper hex socket. None of the sets I bought worked
Old 07-22-2011, 06:24 PM
sweezo's Avatar
where did you get it?
Old 07-23-2011, 03:42 PM
Oreilly
WayneMurray1
01-06-2012 11:36 AM
jimkochuyt
05-31-2011 11:34 PM
jsmz
09-26-2008 11:55 AM
davtak
09-20-2007 10:16 PM
AleroGuy
09-01-2006 10:57 PM
Quick Reply: 89 s10 blazer tips on changing pads?
