How to get at EGR Valve?????
Old 12-22-2007, 12:50 PM
ptcoins's Avatar
ptcoins is an unknown quantity at this point
Default How to get at EGR Valve?????
1992 S-10 4.3L vortec, vin "W"
This truck is an absolute piece of crap.
Old 12-22-2007, 02:12 PM
Default RE: How to get at EGR Valve?????
No need for the language.
Lets see here. 10mm socket and a 6" extension should get you right there. If you're still looking for it, its located under the throttle body.
If you are getting this frustrated removing the EGR valve, go do something else for a bit.
Old 12-22-2007, 04:10 PM
ptcoins's Avatar
I'm just extremely over frustrated. I think I may blow my truck up. Haynes manual made it look simple...too much in the way. can't stand it anymore, I'm done working on it. way too much stuff to go wrong.
Old 12-22-2007, 07:41 PM
x33camaro's Avatar
x33camaro is an unknown quantity at this point
Its quite easy to get out. Take a break from it and go back tomorrow. To make it easier to get out, take the ac bracket that is bolted to therear of the ACcompressor off. Its attached to the intake corner and back of the ACcompressor.(Its anL shaped bracket)Once that is off you can swing the egr valve out in that direction. It will never come out the front unless you do alot of disassembling. You can use a 10mm wrench to get at the left bolt and the right will have to come out with a socket.
I have a 92 Blazer.
good Luck
Old 10-05-2009, 04:01 PM
boscoedoodle's Avatar
boscoedoodle is on a distinguished road
I'm on my third s10. First was a wonderful 96. It had to have a rear main seal around every 50k miles. The way I treated it, NO complaints, 2nd one was a 92, ahhh "little blackie". a slacker totaled it.Now I have a 93, love it, even with a few problems. Hope I am always able to keep a first generation s10.
take it easy, take your time...these egr's come out..
Old 10-05-2009, 06:57 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
You do realize this post is 2 years old, right? I sure hope he's gotten it off by now...
IndianaBlazerGirl
09-06-2011 06:22 PM
BlaziNator
10-26-2009 03:43 PM
yzf125
16
06-18-2007 02:47 PM
khalid_20879
03-14-2006 04:23 AM
dobbist
Engine & Internal
05-01-2005 04:02 AM
Quick Reply: How to get at EGR Valve?????
