93 back window squeak
Old 04-01-2005, 07:29 PM
m00nwater's Avatar
m00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond repute
Default 93 back window squeak
I haven't actually located the precise point the noise is coming from, but I thought I would throw it out to others that may know what part actually causes squeaking from the back window. I know that it is a prevalent problem in Blazers, so if anyone knows what usually squeaks and how it can be fixed (or at least quieted), I'd love to hear about it. I will probably do some more research on my truck to see if it can be more precisely pinpointed.
Old 04-11-2005, 05:12 PM
Jovian2k is an unknown quantity at this point
Default RE: 93 back window squeak
I have a 97 2dr with the spare tire and I have the same problem with the squeaking ...
Old 04-13-2005, 10:30 AM
Atrix_2004 is an unknown quantity at this point
Mine does the same thing. The guy I bought it from thought it was the spare tire rack, so I'm taking it off within the next couple of days, I'll let you know how it works out.
Old 04-13-2005, 11:25 AM
m00nwater's Avatar
Mine doesn't have the rack...my tire is mounted inside my truck...
Old 04-14-2005, 11:49 AM
Did you check the neumatic actuators, if they're not firm, they could be the source of the noise.
Old 04-19-2005, 11:53 PM
Im_Bryan is an unknown quantity at this point
Hey guys theres a simple fix for that...
I had the same problem and was able to fix it in a few minutes... Is what you need to do is wipe down the rubber weather stripping around the window and the rubber stopper if you have a tire rack on back... Use something that will make the rubber more plyable... If I remember right I think I used baby oil. Also oil up the latch that locks in the rear tire rack.
Hope this helps...
Bryan
Old 04-20-2005, 12:23 AM
dobbist is an unknown quantity at this point
ive also heard people that wraping some athletic tape around the latch will help. personaly i just put in a set of 12 inch subs with an 1800 watt amp so now i dont "hear" any sqeak [sm=icon_rock.gif]
Old 04-20-2005, 12:26 AM
Hey thats the way to go... I have a Kenwood 1800watt system with a set of 12's Rockfords and that takes care of any noise.... LOL
94s10blazin
09-24-2018 10:38 AM
WickedBlazer
09-12-2012 03:14 AM
babeba67
11-17-2011 09:35 AM
thrash902
09-15-2010 10:52 PM
farleyeod
11-07-2007 11:09 PM
Quick Reply: 93 back window squeak
