'93 blazer oil drain plug location
93 blazer S10 4x4
Stupid question but it is not as obvious as I thought- where is the oil drain plug located? Should it have a bolt that needs a wrench or an allen-key head that's a bit closer to the rear.
Thanks,
Thanks,
RE: '93 blazer oil drain plug location
Engine oil drain plug will be located in the lowest portion of the sheet metal oil pan and will be a hex head bolt requiring a wrench. It is possible that you have a skid sheild obstructing your veiw of the bottom of the motor.
Thank you Sir! it indeed was hidden by a skid shield.
No problem. That's what we're here for!
boulonman
03-05-2007 05:10 AM
2001Blazer4x4
03-02-2005 10:45 PM
