Another mystery vacuum hose
Old 10-30-2013, 01:23 PM
TennesseeBoy's Avatar
TennesseeBoy is on a distinguished road
Default Another mystery vacuum hose
Ok, found another vacuum hose I have no idea where it goes while chasing down vacuum leaks. Can you guys help me with this one, too. It's a really small line (like the one off of the bottom of the throttle blade housing on the manifold) with a Tee/Wye coming out of it with two short peices of 5/32" hose hooked to it.
P.S. I hope to help you guys as much as you've helped me one day
Old 10-30-2013, 02:12 PM
Ok, traced it out, the other end attaches to the canister under the driver side headlight. It's one of the tiny vacuum hoses. Where should the end in the picture hook up to? Thanks.
**edit** Found where it goes, hooked it up. no change, oh well. I'll keep looking for what's causing my 4.3 to lope. Thanks.
Old 11-03-2013, 10:03 AM
TheRemedy's Avatar
TheRemedy is an unknown quantity at this point
It looks pretty similar to my problem, was a small tube going to the interior. For reference:
https://blazerforum.com/forum/1st-ge...se-help-80416/
Old 11-05-2013, 07:16 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
just for clarification. That end in the picture got hooked to the back of the intake right? There are only 2 lines on the intake, that one and the booster line. The tee goes down to the trans mod valve and the far end of the split on mine goes to a 4 way tee that gives vacuum to the transfer case, cruise control, blend door actuators, and vacuum ball
Old 11-06-2013, 05:16 AM
Yeah, I got it hooked back up, but didn't make a big difference. I thought t went to the charcoal canister, though. I'll look again. Thanks for the help!
dougk
01-22-2013 06:59 PM
Dadatone
09-23-2012 03:37 PM
drblaze
02-22-2011 05:41 PM
sloick
03-13-2010 07:03 PM
vmx120
09-12-2005 07:10 PM
Quick Reply: Another mystery vacuum hose
