Cruise control 1993 Blazer
Old 08-21-2016, 12:17 AM
Davidg65's Avatar
Davidg65 is on a distinguished road
Default Cruise control 1993 Blazer
The cruise control cable on my Blazer is broken. My question is has anyone repaired or replaced just the cable? If so what cable did you use and how did you do it? If you replaced the whole cable and housing then where did you find one? Thanks for any input.
Old 08-22-2016, 07:59 PM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
You could try Truck Parts & Truck Accessories for Chevy, GMC, Ford & Dodge Trucks | LMCTruck.com
Or going to a pull it yard and snatching one off a wrecked blazer/jimmy/bravada around the same year.
Old 08-24-2016, 11:28 PM
Davidg65's Avatar
Default I think I fixed it
Well being a machinist all my working life I have the tools and abilities to fix most things. So to fix the broken cruise control I just needed to replace the cable right? What I did was to go down to my local bike shop and buy a $4 cable of the same diameter. I machined a new end that pulls on the throttle valve out of aluminum with a hollow sleeve for the cable to go into and a threaded end to attach the eye loop. I put it all together and made a swaging end ring the same size as the original cut the cable to length and swaged it together. now to put it back in and try it out. I had priced one on line and it was $89, ouch too much for me so I went the $4 rout. Much more satisfying to fix my own parts better than factory.
Old 08-25-2016, 11:50 AM
mr.vls's Avatar
mr.vls will become famous soon enough
Did you take any pics?
16sweetangel
Engine & Internal
09-22-2013 03:13 PM
Xk49
03-31-2012 06:23 PM
Matt Krogman
12-06-2011 05:08 PM
CompTechMike
02-22-2011 01:14 PM
Luftwaffe
03-22-2009 02:07 AM
Quick Reply: Cruise control 1993 Blazer
