instrument cluster lights go out
Old 09-03-2014, 04:04 AM
Marley666's Avatar
Marley666 is on a distinguished road
Default instrument cluster lights go out
need some help - have a '94 S-10 Blazer and the cluster lights randomly go out. Smack the dash and they come back on(if they want/if not, smack some more)
Wasn't sure if its most likely just a loose connection behind the dash or not....any suggestions would be great.......thanks
Old 09-03-2014, 08:00 PM
odat's Avatar
odat is on a distinguished road
prob a cold solder joint - well known for them
Old 09-03-2014, 08:40 PM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
Digital or analog gauges. But either way, what odat said, most likely a cold solder joint. If you pull the cluster and go over each solder joint with some fresh solder (no need to remove the old solder) it will be working right.
Now, the reason I asked if its analog or digital, will determine on how many solder joints you have to do LOL
Old 09-06-2014, 10:28 AM
Marley666's Avatar
It's digital...
Old 09-10-2014, 06:16 PM
richphotos's Avatar
Originally Posted by Marley666
It's digital...
Oh boy. I have had my digital cluster apart to repair the power supply, LOTS of solder connections on them. LOTS
Old 09-14-2014, 10:40 PM
BlueWorld's Avatar
BlueWorld is on a distinguished road
Does the backing light go out? Or does the engine cluster lose power?
error_401
03-17-2008 06:39 PM
DoubleSprings
09-15-2007 11:20 PM
Russ57
05-14-2007 01:43 AM
FJ40sRock
03-05-2006 04:48 AM
Quick Reply: instrument cluster lights go out
