no spark at spark plugs
Old 06-01-2013, 11:48 AM
blazzer's Avatar
blazzer is on a distinguished road
Default no spark at spark plugs
I have a 1992 s10 blazer with 4.3L tbi 4x4. last week the oil pressure sender went out i replaced it started it up drove about 10miles made it home no problem. then it just died when i pulled into my driveway ever since then i haven't had any spark to my plugs. replaced ignition coil, new distributor, new wires, new plugs. turns over good fuel pressure need some advice. what could be causing this.
Old 06-01-2013, 12:12 PM
newguy's Avatar
Check the ecm fuse under the hood, 15 amp
Old 06-01-2013, 04:34 PM
blazzer's Avatar
do you know about where the ecm fuse under the hood is can't find it. i have two under driver side dash fuse box. both are good.
Old 06-01-2013, 05:11 PM
newguy's Avatar
Not sure on a 92, had a similar issue on mine last week, it was a short causing a blown fuse ecm
Old 06-04-2013, 03:01 PM
blazzer's Avatar
Ok looked for the fuse under hood couldn't find one. Just wondering by some chance could it be my alternator. Cuz I know it will run without battery connected.
Old 06-04-2013, 03:24 PM
Lanny's Avatar
Lanny is on a distinguished road
Running with the battery just means the alternator is putting out, which is good. but you also run the risk of fryin the ecm....as for the fuse location...check either tucked up in the driver fender or on the passenger side firewall...
good luck
Old 06-04-2013, 03:29 PM
blazzer's Avatar
good luck
Thanks ill check it out when I get home
Old 06-04-2013, 04:40 PM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
92 has the only fuse box under the driver side dash. make sure the sending unit is still plugged in, lol and check for broken wires
JavierEscalonJr
10-14-2020 11:38 PM
abe_f
04-01-2013 11:19 PM
Yankee Team1020
23
08-03-2011 08:05 AM
yzf125
11-03-2005 12:55 AM
thorbergdt
Engine & Internal
01-05-2005 10:02 PM
Quick Reply: no spark at spark plugs
