08-20-2005, 10:06 PM
stalls under heavy acceleration
92 chevy s10 blazer, 4.3 liter, automatic. Engine runs fine before it reaches operating temperature. When it reaches operating temperature it will stall under quick acceleration, but I can accelerate it slowly and it won't stall. I changed the plugs, wires, cap, rotor, and the coolant sensor and sender. The truck won't set any codes.
08-21-2005, 10:53 AM
RE: stalls under heavy acceleration
Have you tried a fuel filter yet? It sounds like the moter is starving for fuel. Also check fuel pressure.
Paul
'93 S-Blazer 4.3 "W"
__________________
Paul
08-21-2005, 09:58 PM
I changed fuel filter, fuel is fine. leaning more towards the timing.
08-22-2005, 10:06 PM
I'm not really sure that timing is your problem from the symptoms you described, but what the hey, give it a try. Make sure you put it in base timing mode before you check the timing.
__________________
Paul
08-23-2005, 10:58 AM
The timing may be off
Check that and your air filter (not that it will make it stall, a dirty filter just doesn't help)
__________________
1997 GMC Sierra Z71
Vortec 350
Spark It or Park It
In Loving Memory of Matt Jones
12/30/85 - 11/06/05
08-23-2005, 11:35 AM
What kind of air intake do you have?
On the older intake (snorkle with round air filter on top of engine intake) there is a temperature controlled flap. It is designed to suck in hot air off the exhaust manifold (hose coming off exhuast manifold and running into intake from the bottom) until it warms up. Then the flap will close and allow more fresh outside air into the intake and less exhaust manifold air. About the only way to check that is to look down the snorkle and watch the flap. Do this in the morning when its the coolest out. Is the flap stuck open, does it move as teh engine warms up?
I also doubt its your timing, unless you have messed with the distriburator at all. Well other then changing cap and rotor. The PCM pretty much controls minor timing adjustments so you don't have too.
When is the last time you serviced the EGR valve?
__________________
"Some people spend an entire lifetime wondering if they made a difference.
The Marines don't have that problem."
-President Ronald Reagan
'87 S10-Blazer - SOLD
'93 S10-Blazer 4x4x4 - Sold
'00 S10-Blazer 4x4x4 - 212,000 miles-Sold
'04 Trailblazer 4x4x4- 56,000 miles new DD.
Tags
1997, 350, 43, 87, acceleration, aceleration, blazer, chevy, dies, heavy, s10, stall, stalling, stalls, symptoms  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
