Tailgate lock
Old 09-02-2013, 10:26 PM
rstrosky's Avatar
rstrosky is on a distinguished road
Default Tailgate lock
I have a 1990 S10 Blazer 4x4 Tahoe Edition....I can't get the tailgate to lock with the key, The oval key goes in but will not turn in any direction...Did these trucks come with 3 keys...Is there a trick to this I don't know about OR or is the lock/handle assembly needing to be replaced? I've seen them available new online for $15 or so with keys included....That's why I was wondering if these trucks had a separate key for that.
Old 09-03-2013, 06:18 AM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
the original key locked the doors and tailgate,if its been changed then they came with new keys. Honestly get it at the dealership. Ive gone through 3-4 cheap locks in the last 6 months. Sure enough i can change one out now in 5 minutes with channel locks and a screw driver,it still sucks.
Old 12-10-2014, 11:31 PM
chuck333's Avatar
chuck333 is on a distinguished road
Default My 84 S10 blazer tailgate lock
My 84 S10 blazer tailgate lock will only open the glass and wont open the tailgate, i tried changing the lock cylinder thinking that was the issue since the other one was free spining, but i still hae the same issue. Help!
Old 12-18-2014, 12:37 PM
raysrh's Avatar
raysrh is on a distinguished road
Default Tailgate
Maybe you didn't put in right. The lever on the end of the cylinder assembly has a L shaped lever on the end that pushes down the lever that unlocks the gate. If the L shaped lever isn't above(I think) the horizontal lever running to the side of tailgate it won't open it.
Old 12-19-2014, 06:13 AM
mr.vls's Avatar
mr.vls will become famous soon enough
I have an 89 that I am the original owner. There were two keys one square and one oval. You can remove the lock and take it to a locksmith to match your key or replace pins. If you buy a new lock, I would still take it and have it keyed by a lock smith so you do not have to have 3 seperate keys. One for ignition, one for doors and now one for the back glass. When I replaced my rear lock I went and had it keyed to match my door keys. Any independent lock smith shop can do it very easily.
Old 12-20-2014, 11:36 AM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
I would bring the OEM lock to a lock smith, usually the problem can be repaired, and will be cheaper than a replacement and last much longer. My gate lock did this same thing. Found one at a pull it yard with the keys. took it apart, got the parts I needed from a lock smith, and its still working 100%
RobRad
03-24-2014 06:08 PM
Spectreblazer
02-18-2010 08:09 PM
Qumodo
01-08-2010 08:39 PM
Roma
07-04-2007 07:40 AM
USMaverick101
11-20-2006 01:20 PM
Quick Reply: Tailgate lock
