Go Back   Blazer Forum - Chevy Blazer Forums > Mechanical & Maintenance > General Tech Help > 2nd Gen S-series (1995-2005) Tech
Sign in using an external account
Register Forgot Password?
Search
Welcome to Blazer Forum!
Welcome to Blazer Forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Blazer Forum today!
Reply
LinkBack Thread Tools Search this Thread
Old 12-12-2009, 08:26 PM
KC-BodyMan is on a distinguished road
Angry 2000 Heater switch stuck in defrost
Hey i got a 2000 s-10 blazer 4x4 4.3 with a heat problem. I seems the heat is comming out of only the defrost. I have checked vacuum lines under hood and behind dashboard and found no problem. I had glanced underneath around the transmission but saw no problem with the lines.I read there may be a switch on the tranny where 3 or 4 vacuum lines connect and can get oil in them that will cause the vacuum system to go into fault mode. That switch and the actual heat selection switch is the only things i can think of. Any got any ideas. Thanks.
Old 12-12-2009, 08:53 PM
1974 Chevrolet K Blazer
My Garage
Send a message via ICQ to swartlkk Send a message via AIM to swartlkk
When you checked the vacuum lines at the HVAC control module, did you find any transmission fluid? And was there adequate engine vacuum on the supply line to the HVAC control module?
Old 12-12-2009, 09:12 PM
I never found the exact location of the module, i found 3 or 4 lines running on the top of the tranny and i just went out and pulled one line off of a "Y" junction and tranny fluid poured out.I do belive theese are all vacuum lines.Do you know the exact where abouts of the module?And do i need to replace all the lines with fluid in them and the module or just the module?Thanks man.
Old 12-12-2009, 09:22 PM
My Garage
Ok... If you found transmission fluid there, then the vacuum switch on the transfer case has gone bad. You likely also have a failed input seal on the transfer case. Pull the fill plug on the transfer case. If transmission fluid pours out, you need to pull the t-case and replace the input seal.
Now, if you haven't pulled the vacuum lines off of the HVAC control module under the dash, then you should do that fairly quickly to see if transmission fluid is there as well.
Reply
Tags
1994, 2000, 2001, 99, blazer, controls, defrost, gm, heater, s10, selector, stuck, switch, transmission, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
