2003 chevy blazer
2003 chevy blazer
This is my problem i need help with last winter my truck was running fine idleing then it just stopped I am not getting any fuel to the fuel filter now. I need help where is the fuel pump relay and is there fuses i should be checking before i drop the fuel tank and replace the fuel pump thank you very much. Walking
Fuel pump relay is in the underhood fuse/relay center. You can hot wire the pump by placing a fused jumper wire in place of the relay to effectively hot wire the pump. If it still does not run, then your pump is bad.
hlaverty06
03-05-2014 07:14 PM
AaronGene02
01-24-2010 11:38 AM
downja
08-19-2008 08:32 PM
celchlepp
01-10-2008 01:24 AM
