Compressor high side switch
Old 05-30-2009, 08:45 PM
camaroz's Avatar
camaroz is an unknown quantity at this point
Cool Compressor high side switch
Does anyone know if the compressor high side switch on the back of the Delphi A/C compressor is a compression fit or screwed in or something else.
The reason I am asking is I bent it while doing a intake seal. The weather turns hot no A/C so I recharge it, that is when I heard the SSSSSSSSSSSSSS sound. Leaking out the compressor high side switch which is now sitting a little crooked. Is it hooped or can I pull it out and reseat it with a new o-ring?
Old 05-30-2009, 10:28 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
I think it just sits in there with an oring on the inside edge and a cring on the outside.
Old 05-31-2009, 07:13 AM
hkellogg's Avatar
hkellogg is an unknown quantity at this point
its pushed in and held in by a snap ring you need to take the compressor out of the cradle to work on it take it out and see, you might need to get a new one though make sure you lube the o-ring with ester oil
Old 06-01-2009, 09:36 AM
The system needs to be emptied to trouble shoot as removing the switch would open the system to atmosphere. I would recommend replacing the switch while it is out. Then you should vacuum the system down prior to recharge to make sure there are no other leaks.
Old 06-05-2009, 08:14 PM
2doorblazer's Avatar
2doorblazer is on a distinguished road
yes it just slips in an a oring around in with the snap ring. dont forget to replace ur dryer if u have the system for a long time thay r realy cheap (just my 2 pennys)
mcdevin1973
10-05-2014 02:52 PM
jakegaisser
04-06-2011 11:35 PM
gmcjimmy_94
12-30-2010 12:37 AM
josh77888
07-24-2010 09:25 PM
1998MSO
06-29-2009 07:17 PM
Quick Reply: Compressor high side switch
