Alternator Interchange
Old 01-29-2013, 06:34 PM
fondo's Avatar
fondo has a little shameless behavior in the past
Default Alternator Interchange
I need to know if an alternator for an '01 s-10 4.3l will fit a '98 bravada. The part numbers don't exactly match up but the person that is selling it says the only difference should be the connector location. Your thoughts? Its a re-manufactured AC delco alty for a steal so I'd like to jump on it if it will work. Thank you!!
Old 01-29-2013, 07:13 PM
My guess is no. 1998 uses an internal voltage regulator, on 2001 the alternator is controlled by PWM from the PCM.
Old 01-29-2013, 07:24 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
You could only use up to 2000 on the altenator.
Old 01-29-2013, 07:48 PM
rexazz2's Avatar
Old 01-29-2013, 07:49 PM
fondo's Avatar
Thank you much!!
DFINE160
12-07-2009 12:17 PM
eelding
04-26-2007 12:20 PM
MNHawk
12-21-2006 09:38 PM
MIKE82
11-15-2006 02:16 AM
ginobass
09-11-2006 05:16 PM
Quick Reply: Alternator Interchange
