Need ABS, SRS Code Reader
Wondered if anyone on here could recommend a good abs, srs code scanner that will work on s10 & blazers, jimmys etc... for under $500. Been looking at the autel md802 mxdiag. What is everyone else using ? Need it to check airbag codes on my 97 jimmy, been on since i bought it, my 98 sonoma highrider, been on since heater core install, think my brother in law forgot to disconnect the neg battery terminal during install. Thanks
For well under $500 you can get Autoenginuity software and access most of the network, and it has some bi-directional capabilities too. It's a no brainer.
http://www.obdii.com/scantool_selection.html
This one will fit the bill. Freeze frame and live data along with what you require.
I have been told that the 97 ABS and SRS (airbags) modules for a 97 GM vehicle are on the older OBD1 bus. That is physically and logically separate from the OBD2 bus of the PCM. Is this true?
I have a couple of scanners (Actron CP9580, Palmer Performance GM Enhanced) that read ABS but cannot read the ABS on my 97 S10.
Northern Z7
08-30-2013 10:39 PM
frisky-maddog
06-04-2013 10:20 PM
