Passenger side of 99 blazer sits alot lower then drivers side ?
I have 99 blazer with 4wd and over the past couple years I have noticed the passenger side starting to drop lower than the drivers side. when you stand in the back you can see that the passeneger side sags alot lower than the drivers side. If I measure both sides from the top of the wheel to the to fender there is about a 3 inch difference. Can I bring that side back up by adjusting the torsion bar nut. I was thinking about getting some helper springs for the leaf springs but I was not sure it that would lift the passenger side back up. Does anyone have any idea as to what I can do to raise that side back up.
You could try cranking on the torsion bar. But if the entire passanger side is leaning it'll only help the front. Check the leafs, compare them to the left side. Do they look flatter? Anything broken?
Still check the torsion bar though, check it for cracks, or any signs of distress. Also check the control arm where the torsion bar slides in. Check for looseness or anything else strange.
krzldy1949
08-19-2017 05:18 PM
jakegaisser
04-06-2011 11:35 PM
2003ZR2
09-14-2010 03:02 PM
duckieboi
05-14-2007 01:59 PM
hillbillyinOhio
07-12-2006 04:18 AM
