87 s10 Blazer right sides sits lower
Old May 14, 2007 | 07:40 AM
duckieboi's Avatar
duckieboi is an unknown quantity at this point
Default 87 s10 Blazer right sides sits lower
Have an 87 s10 blazer 4x4 that has a 3" lift. The other day
while making a u-turn I heard a rubbing, creaking sound coming
from front end. Assumed it was the plus size tires rubbing
on the fender well, as it does sometimes with a sharp turn.
But once I got it home I noticed the right side, (looks like the
front moreso than rear) is now sitting lower than the left.
The shocks seem just fine. Runs just fine, but goes
'thunk' no bounce over any type of bump. Any ideas?
Old May 14, 2007 | 01:59 PM
thegr81's Avatar
Default RE: 87 s10 Blazer right sides sits lower
did you check your spring seat sometimes if the spring isn't seated properly it can create a clunk also check your ball joints for excessive play if you replaced them with the lift but find that they have excessive play they might allready be bad or diffective one other part to check is the shock out of the vehicle therefore taking away the spring to test the shock on its own you might have an internal seal blowout or there's a leak also check the rear of the same side another way to test the suspension is with a bounce and rebound check by depressing the corner making the noise up and down by your own force try to recreate the noise with the vehicle off and you right by the corner that it is clunking in doing this should bring you to the conclusion of what is causing the problem
julioAKAjunior
Feb 12, 2013 09:52 PM
upmaine
Jul 9, 2012 12:31 PM
ZachL90
Jun 21, 2010 11:15 PM
bigdaddykane93
Jan 14, 2010 06:56 AM
tdannar
Suspension Tech
Oct 27, 2005 03:24 PM
