Po452
Old 03-11-2010, 02:47 PM
wlorton's Avatar
Default Po452
SOOOOO this is the code...
Evapo leak? or sensor problem is what mr autozone said...
Where do I start?
Also my rear suspension is creaking like an old person!!! could that just be bushings?
Old 03-11-2010, 03:42 PM
Old 03-11-2010, 04:35 PM
wlorton's Avatar
THANK YOU
I searched PO452 and found nothing
Old 03-11-2010, 05:19 PM
Try a 0 (zero) instead of an 'O'.
Old 03-12-2010, 05:44 PM
wlorton's Avatar
Just realized that... Guy at Autozone, said it would need new lines, while second guy at different autozone said it could be caused by "overfilling" my tank, because I mentioned I top it off everytime.....
He also noted that its a 46 dollar sensor and that he couldnt clear the code... But he then coughed *remove the ground* if its bothering that much...
Thanks again, I will be checking this out, and he also mentioned if there was a problem that I would start smelling gas...
KYLE SAVES THE DAY!!! AGAIN!!!
Old 05-19-2013, 10:49 PM
teklife25's Avatar
teklife25 is on a distinguished road
I also have a p0452 on my 99 blazer. Were you able to resolve the issue?
Old 06-07-2013, 07:34 PM
Mike Phillips's Avatar
Mike Phillips is on a distinguished road
Trouble Code: P0452 (4.3L V6 VIN W Auto)
Fuel Tank Pressure Sensor Circuit Low Voltage
Number of Trips to Set Code: 1
  • CCM Details
Trouble Code Conditions:
The ignition switch is in the RUN position.
Possible Causes:
  • 1. Inspect the Control Module harness connectors for the following conditions:
    • Improper mating
    • Broken locks
    • Improperly formed
    • Damaged terminals
Old 06-07-2013, 09:01 PM
This link has complete flow charts for all DTC's:
https://blazerforum.com/forum/tech-a...agnosis-26408/
jim109
10-09-2012 07:58 PM
kevlar974
09-11-2011 08:59 AM
Quick Reply: Po452
