ignition lock won't release key
Old Apr 25, 2011 | 09:16 PM
vracer99's Avatar
vracer99 is on a distinguished road
Default ignition lock won't release key
2004 Blazer Extreme with console shifter. A couple weeks ago started randomly not being able to remove key from ignition switch after put in Park. Could shift up and down a few times and eventually would release key. Today nothing I try works. My immediate concern is getting the key out of the ignition. I tried pushing a ball point pen and also a small screwdriver thru the hole in plastic cover under the steering column. Mine is almost under the center of column, not offset to the right side closer to the switch. This didn't even work. My question is what should I use for this. What am I trying to hit inside this hole? Is there a button that releases the key? Or should I use something like an icepick that would go in a smaller hole pushing the release pin? Please I hope someone can help. Thanks
Old Jun 6, 2013 | 11:17 PM
toolio's Avatar
toolio is an unknown quantity at this point
My Blazer is a 1997 with the hole to the right of center. I use a screwdriver.
On the advice of my mechanic I took the top off the shifter console and sprayed the shifter mechanism with carb cleaner.
It fixed my problem. Now when I depress the button on the shifter I can hear a relay click in the dash and the ignition key will release when I turn it off.
Old Jun 7, 2013 | 09:30 PM
golfpgb's Avatar
golfpgb is on a distinguished road
I had the same problem with my 2004 Blazer. The first time I replaced the shifter mechanism and it took care of the problem. It happened again about two years later.
This time I wired a push button switch in the circuit to energize the key solenoid to release the key.
Old Jun 7, 2013 | 09:36 PM
blazzer's Avatar
blazzer is on a distinguished road
Had same problemwith my 92 blazer just replaced ignition switch no problems afterwords
Old Jun 7, 2013 | 10:42 PM
blown262's Avatar
blown262 is on a distinguished road
I have had this same problem before, also. From what I was able to determine with mine, there is a relay activated by the brake light switch, which in turn allows the shift lock to disengage when you depress the shift lock button. There is also a micro switch that detects when the shift lever is in park. This is where my problem was, but in order to rectify the situation, I needed a new console shifter. Luckily, my local scrapyard had one for $50 and I never had the problem again, except the new shifter was bent, and it needed to be straightened to release the lock button. Search on here for threads containing shift interlock and stuck key problems. This isn't a rare problem
Jay Cramer
Apr 22, 2015 12:56 AM
Tom Lusk
May 25, 2014 04:12 PM
Dark Rider
Aug 8, 2010 11:57 PM
49er_Dirtbag
Jan 14, 2010 06:43 PM
pilgrim
Jun 23, 2006 11:48 PM
