Remote Oil Line Hose Diameter
Old 06-04-2013, 02:15 AM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
Default Remote Oil Line Hose Diameter
Since I've got the '98 Jimmy up on jack stands in the garage from troubleshooting the P0420 I decided today would be a good time to replace the leaky remote oil lines. I did a lot of reading about various solutions people have tried, both on this forum, on the S10 Forum (of which I am also a member), and various other places on the Internet. I didn't want to spend the money on having custom hydraulic lines built so I didn't go that route although it is very impressive. I also don't have the skills for braising so I crossed that off the list. I didn't necessarily want to replace newly-leaking lines in a couple years so I skipped buying the replacement crimped lines. I chose the method outlined on the S10 Forum...
Repair your leaking oil cooler lines! (Pics fixed) - S-10 Forum
I went to NAPA to get all the parts so I would have them on hand. I took the oil lines and oil filter adapter off the block and got everything out where I could clean and degrease them. The adapter went back up in place with brand new gaskets. I was careful to torque the bolts down to factory spec.
Things got weird when it came to the oil lines. When I removed the lines from the filter block behind the bumper I found that there were two sets of washers on the end of the lines. There was the normal set of rubber washers in a steel enclosure and also a set of rubber washers covered in some type of silicone. That made me suspicious that someone previously had done some kind of work on the lines.
I cut the aluminum crimps off the lines and cleaned them up per instructions. I measured the replacement 1/2" hose to cut it to length. Before I cut the hose, however, I checked to see how well it fit onto the aluminum lines. It was way too large. The hose I took off the aluminum fittings said it was 13/32". At that point I stopped and went to AutoZone and just bought the Dorman replacement lines.
Are the factory lines actually 1/2" or are they 13/32"? I suspect that the truck had some kind of aftermarket replacement lines. The lines were not double-crimped like what I've heard of factory lines; they are triple-crimped.
Old 06-04-2013, 11:10 PM
abig84's Avatar
thats a pretty cool fix, just keep a eye on the hose clamps as they will loosen up as the rubber hose smashes over time. thats pretty much where they always leak too is on that crimp.
when i bought my 93 they were leaking i did the even more fullproof repair and bypassed them and threw them in the trash. and just mounted the oil filter to the block but i also ripped out my factory front diff so lot of room to mess around
Old 06-05-2013, 02:35 AM
I didn't do the hose clamp rebuild on the lines. The hose that was recommended in the post from the S10 Forum was too large for the lines that were on there. I didn't want to waste any more time on it so I just got the Dorman lines from AutoZone and called it good for now.
99bblazer99
02-21-2014 08:01 PM
Captain Hook
24
09-29-2011 07:59 PM
mchap87
08-02-2009 01:53 PM
nnnon632
03-20-2009 04:14 PM
Quick Reply: Remote Oil Line Hose Diameter
