Replacing MFI spider, FPR, and manifold gaskets
Old 07-03-2010, 05:39 PM
Patrick_Boyle's Avatar
Patrick_Boyle is an unknown quantity at this point
Default Replacing MFI spider, FPR, and manifold gaskets
I'm getting ready to service our 2001. It's been progressively getting harder and harder to start due to a leaking FPR. I'm going to upgrade it to MFI in the process with p/n19210688. I'm also leaking coolant down the side of the block towards the tranny. I've got the Fel-Pro intake manifold gaskets to hopefully cure that problem. So the throttle body and lower intake plenum are coming off. I'm also doing plugs, cap, rotor, fan clutch, motor mounts, and replacing vacuum lines.
Is there anything else I should be thinking of. Anything to look out for when taking off the plenum?
Old 07-08-2010, 09:38 PM
rdlyn's Avatar
rdlyn is on a distinguished road
You may have seen this before, but it's a pretty good write-up. Probably has more than you need, but still...
let me know how the mfi swap works out. I'll be doing that myself next week.
http://www.handymanlyness.com/archiv..._99_Jimmy.html
Old 07-09-2010, 12:30 PM
rdlyn's Avatar
...and for the spider:
http://www.automotiveforums.com/vbul...d.php?t=559014
apologies in advance for posting links to outside the forum.
good luck!
koreiryuu
08-26-2014 10:09 PM
gsaum
04-09-2013 11:37 AM
shanegreen
04-30-2012 02:38 PM
kc0alg
07-16-2011 09:41 PM
greg94
11-17-2010 09:15 AM
Quick Reply: Replacing MFI spider, FPR, and manifold gaskets
