Sorry, another 4x4 question.
Old 12-13-2012, 04:41 PM
NBraun's Avatar
NBraun is on a distinguished road
Default Sorry, another 4x4 question.
Well, first im sorry for another question. Ive read all the stickies and searched but am still slightly confused.
First off, my situation. This a friends car that im working on for him. Its an 96 zr2 with the Three button option. What happens is, if you push 4hi you can hear it make a noise, then i believe the same for 4lo. I put it on the lift and found the wire from a plug in the tcase to be cut, i found the other part of the wire and soldered it back together. Nothing.
Now onto diagnoses. From what ive read its either the vacuum, tccs, encoder motor, or encoder switch. Im pretty confidant on testing the vacuum reading the stickie. But im still confused on how to test the rest. Ive read that if i ground pin 13 on a switch, it will blink codes if it has any. I have access to a snap-on motis. Will this tell me the same thing? And lastly how do i go about testing them?
If you have any tips/suggestions they're all greatly appreciated in figuring this out. Thanks!
Old 12-13-2012, 06:16 PM
Diaita's Avatar
Diaita will become famous soon enough
if you severed a wire it could be a fuse blown.
Old 12-13-2012, 09:26 PM
aa21830's Avatar
aa21830 is on a distinguished road
Originally Posted by NBraun
I have access to a snap-on motis. Will this tell me the same thing?!
Not exactly sure what the Motis does, but I suspect this is what you might use to diagnose a 4-button (Auto-trac) system. The 3-button system is designed so that grounding pin 13 will reveal the trouble codes stored in the TCCM (if there are any codes stored). You don't want to clear those codes by disconnecting the battery or fuses or whatever other advice you've read about how to temporarily (maybe) get the encoder motor to start working again (which along with vacuum leaks is probably the most common reason for inoperable 4WD).
Old 12-13-2012, 11:48 PM
NBraun's Avatar
The motis is like a super advanced OBD reader. Might as well try it and see if anything comes up. When i fixed the wire i checked the fuses and the fuse wasn't blown.
Christine1199
03-09-2014 08:17 AM
Dubie81
01-02-2013 08:26 PM
Thogert
07-13-2011 06:02 AM
GolfClapperX
02-13-2010 09:15 PM
uncle larrys oranges
Tires and Wheels
01-19-2010 05:56 AM
Quick Reply: Sorry, another 4x4 question.
