Steers Right
Old 08-14-2013, 09:52 PM
Muchempo's Avatar
Muchempo is on a distinguished road
Default Steers Right
99 Jimmy new Moog ball joints, end links, front sway bar bushings and CV axles Does not pull when braking. 2 alignments later shop says idler arm needs replacement. What other steering component could cause this type of issue. Thanks for reading.
Old 08-14-2013, 10:57 PM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
pulling to the right is either sticking brake or bad alighnment (camber angle). It's a 4x4 so camber is an easy adjustment. Also the tires on the front have to be the same, if the sizes are different they will pull, if air is low in one it will pull, sometimes even the tread pattern can make it pull.
Old 08-15-2013, 10:59 AM
LeWhite's Avatar
Caster can cause a pull too! The car will pull to the side with less caster. MOST alignment shops dont check caster.
Old 08-15-2013, 12:16 PM
Muchempo's Avatar
looking at the data sheet the alignment shop provided me it looks like Camber was off -0.7 degrees (front left) and was adjusted to be within spec 0 degrees. (front right) was with in spec -0.3 degrees and was not adjusted. Caster was within spec FL 2.0 FR 2.5 degrees
Tires are same size 235/75/15 I have rotated them frequently to try and keep the tread pattern even but the pulling has worn the inner front tires. The first alignment was performed with new tires though and at the time pulling was slight and progressively has been getting worse.
Old 08-15-2013, 09:28 PM
how was the toe? that eats tires
Old 08-16-2013, 10:21 AM
Muchempo's Avatar
Toe before alignment FL -0.25 FR -.027 both were brought back within spec 0.05 and 0.08.
Old 08-16-2013, 10:43 AM
if the alighnment is as you say then it is correct. inner tire wear is signs of too much negative camber.
The only thing i can think of is either you drive on roads with a slant or there is a brake or something sticking on the passenger side making it pull. How bad is the pull? You let go and it slowly drifts off or is it sudden and constanly having to fight it?
Old 08-16-2013, 11:26 AM
Muchempo's Avatar
yeah i thought is was the roads but taking it on newly paved roads and straight highways does the same thing, if I let go of the steering wheel it veers to right gradually maybe a couple seconds before i have to grab back on and bring it back. I will check the brakes I had asked the shop to do so not sure they did tho.
aarussell
01-06-2010 02:15 PM
boscoedoodle
11-03-2009 12:33 PM
kikkegek
Tires and Wheels
20
10-12-2009 08:04 AM
redpeppers
04-07-2007 04:55 AM
DanishDonut2
09-09-2004 05:17 AM
Quick Reply: Steers Right
