Vacuum Leak?
Old 08-09-2005, 08:55 PM
doom1701e's Avatar
doom1701e is an unknown quantity at this point
Default Vacuum Leak?
I have a 95 Blazer Vortec V6 and I have been noticing a hissing noise coming from behind the top of the engine near the firewall. Also when I shut off the car the hissing noise last for a few seconds and then stops (like a depresurizing noise). It is possible that there may be a vacuum leak somewhere behind the engine? Or could it be something else? If it is a vacuum leak, where should I look for problems (Its hard to see behind the engine). Thanks.
Old 08-09-2005, 10:32 PM
mrjoeyjiffy is an unknown quantity at this point
Default RE: Vacuum Leak?
look for a foam hose near the firewall on the driver side, it should be connected to that plastic ball looking thing thats attatched to ur hood, basically the ball is sort of a cleaner for the vacuum and it also holds a little pressure after you turn the truck off, mine became detatched and i just tied the hose off as a temporary solution.
Old 09-08-2005, 09:16 AM
vmx120 is an unknown quantity at this point
Had the same thing on my 94. Its hard to get at but right behind the distributor there is a junction of a few vacuum hoses and one of them runs into the back of the distributor. That one had a split and fell off.
cjb2145
18
10-06-2018 04:46 PM
ebcjlc
01-03-2008 08:05 PM
Jharper
12-19-2007 08:47 PM
kfk4nf
11-02-2007 09:59 PM
magnum434
08-15-2006 12:39 PM
Quick Reply: Vacuum Leak?
