2004 ZR2 Brake Lights
Old 02-21-2012, 06:51 AM
mkm1387's Avatar
mkm1387 is an unknown quantity at this point
Default 2004 ZR2 Brake Lights
My brake lights have been acting up where sometimes the bottom two lights will not light up when the brake is engaged but the top brake light strip always engages. If I tweak the brake pedal, or kind of push it to one side then the bottom brake lights will also go on. I was wondering if this would mean that the switch is faulty. Are the bottom lights separated from the top one in the switch? I bought a new switch but I have no yet installed it. Im wondering if mine is just loose. How does the switch mount to the pedal? Its hard for me to tell...it looks like there is some kind of pin under there that holds it in place. Please help! Thanks.
Old 02-21-2012, 08:44 AM
pettyfog's Avatar
Look at your new switch. Note there is a C-shaped opening opposite a hole.
Use a flashlight and look closely at the junction.
You pull the hairpin clip, slide the switch and actuator over until the hole in the switch clears the pin.
Push it up and away from the pedal pin. You do not have to pull the actuator all the way off the pedal pin, that's why the C-shaped opening
Pull the switch down for clear access and release the harness connector catch and pull the connector.
Install the new switch and install the hairpin clip.
Push harness connector into switch
{NOTE: I dont think the curve shown on the pedal lever is correct. Think it should be the other way.. dont let it confuse you}
__________________________________________________ _________
All that said, I dont believe it will fix your problem. The usual solution to your problem is to look at the hazard switch. It could be that moving the pedal slightly improves the brake switch contact.
Old 02-21-2012, 11:16 AM
mkm1387's Avatar
what could be wrong with the hazard switch? do you think the switch that mounts to the pedal arm is loose?
Old 02-21-2012, 11:40 AM
pettyfog's Avatar
The better question is 'what couldnt!'
https://www.google.com/search?q=brak...lazerforum.com
No.. the way the switch works, it could be worn. But the HMSL works from the same switch contacts, at least in 99, which uses the same part # yours does.
Just to be clear I advise you to go ahead and change the stop switch. It is probably on the way out.
What I'm saying is dont be surprised if the problem comes back. The fender stop lamps signal goes through the hazard switch which has known problems.
Old 02-21-2012, 01:39 PM
mkm1387's Avatar
the hazard lights seems to work fine though, wouldnt they be acting up if they were going?
Old 02-21-2012, 04:32 PM
pettyfog's Avatar
First let me address your earlier question about something being 'loose' causing the problem.
NO
If you look at the way that switch is made and the diagram above you will notice there is NO adjustment at all. Activation of the switch depends on a designed bit of slop between that pedal pin and the hole in the actuator plus the high spot on the actuator. Which is precisely milled length from the center of hole for the purpose.
This makes the stop switch one of the most relaible component is the car and it works so well that the mechanism is industry standard.. it's been used on every car, mostly fords, that I've owned since 1980. There is no 'fix' and no adjustment. If the contacts do not make properly inside the assembly the only feasible answer is to replace it.
Not always. Perhaps I gave you more info than you can handle. Just wanted to give you heads up. I fully believe your diagnosis that if you press brake a certain way, the corner brakes work. So replace that stop switch. But you might just want to order this to have it handy.
But I am not pulling this out'a my butt:
https://www.google.com/search?q=blaz...+hazard+switch
Rockauto.com
PriceDORMAN Part # 924608
Stamped 15177379
$9.62
04zr2blazer
02-10-2013 05:23 PM
MTopper
07-12-2011 12:19 AM
KarlofZR2
Tires and Wheels
06-28-2010 07:53 PM
mkm1387
Tires and Wheels
10-25-2009 09:24 AM
Zach37mZR2
Engine & Internal
07-16-2009 10:45 PM
Quick Reply: 2004 ZR2 Brake Lights
