Need ABS, SRS Code Reader
Old 01-04-2015, 03:06 PM
schrack's Avatar
schrack is on a distinguished road
Default Need ABS, SRS Code Reader
Wondered if anyone on here could recommend a good abs, srs code scanner that will work on s10 & blazers, jimmys etc... for under $500. Been looking at the autel md802 mxdiag. What is everyone else using ? Need it to check airbag codes on my 97 jimmy, been on since i bought it, my 98 sonoma highrider, been on since heater core install, think my brother in law forgot to disconnect the neg battery terminal during install. Thanks
Old 01-04-2015, 04:36 PM
For well under $500 you can get Autoenginuity software and access most of the network, and it has some bi-directional capabilities too. It's a no brainer.
http://www.obdii.com/scantool_selection.html
Old 01-04-2015, 08:34 PM
canuck blazer's Avatar
canuck blazer is on a distinguished road
Autel makes a good easy to use reader one that reads ABS ANS SRS 300 OR LESS
and they have live data as well as freeze frame
Old 01-04-2015, 09:43 PM
babydeuce's Avatar
babydeuce is on a distinguished road
This one will fit the bill. Freeze frame and live data along with what you require.
Amazon.com: Innova 31603 CarScan + ABS/SRS Scan Tool: Automotive Amazon.com: Innova 31603 CarScan + ABS/SRS Scan Tool: Automotive
Old 01-05-2015, 08:51 AM
burned's Avatar
burned is on a distinguished road
I have been told that the 97 ABS and SRS (airbags) modules for a 97 GM vehicle are on the older OBD1 bus. That is physically and logically separate from the OBD2 bus of the PCM. Is this true?
I have a couple of scanners (Actron CP9580, Palmer Performance GM Enhanced) that read ABS but cannot read the ABS on my 97 S10.
Old 01-05-2015, 04:49 PM
schrack's Avatar
What about under $300 ?
burned
08-11-2014 06:43 PM
Northern Z7
08-30-2013 10:39 PM
frisky-maddog
06-04-2013 10:20 PM
LRV31
09-05-2011 11:19 AM
greety12
12-09-2010 04:25 PM
Quick Reply: Need ABS, SRS Code Reader
