My small 96 Blazer build
Old 10-24-2014, 09:55 AM
WalkGood's Avatar
WalkGood is on a distinguished road
cleaned it up and gave it and the tcase a fancy 5 foot paint job
Is that a paint job that looks good from 5ft away?
  #1342
Old 10-28-2014, 05:15 AM
kenny100034's Avatar
kenny100034 is on a distinguished road
I was looking through this the other day, and my 2 year old son pointed to the pic. of your blazer and excitedly yelled wow monster truck
  #1343
Old 10-29-2014, 04:42 PM
rexmburns's Avatar
Super Moderator
rexmburns has a spectacular aura aboutrexmburns has a spectacular aura aboutrexmburns has a spectacular aura about
Been crazy busy with work lately so haven't had time to update much. I got my gears installed and put about 35 miles on it but I've got some noise on the coast side so I need some adjustment. The backlash is about perfect all around at .008 and I think the pattern looks good but maybe it's shallow? Sorry my pic of the coast side didn't load to PB I guess. It's a little low on the toe but has good contact and from what I've read a little low is semi normal but maybe I'm wrong lol!
I also picked this up for $40 off CL so I can build it into my rear bumper. Yes I should have started this way but I couldn't find a hitch under a $100 that would work until now so I guess I've got work to do!
And not sure if anyone cares but the guy had a nice little SS s10
Sorry the pic sucks I snapped it as I was pulling out of his driveway.
Attached Thumbnails My small 96 Blazer build-985c10f6-2f91-4442-b080-f3824a4fe93b_zpsyd4vr24b.jpg   My small 96 Blazer build-a9edb8eb-1fcd-4491-abc1-06a7a4ba6542_zpsrpze6yr6.jpg
  #1344
Old 10-29-2014, 04:43 PM
rexmburns's Avatar
Super Moderator
Haha that's awesome! My son and now all of his friend at his daycare call it a monster truck as well lol
  #1345
Old 10-29-2014, 05:25 PM
newguy's Avatar
I`m no expert either but from the research I`ve done it looks like maybe could be a bit deeper.
  #1346
Old 10-29-2014, 05:32 PM
rexmburns's Avatar
Super Moderator
That's kinda what I was thinking. It's just hard to keep the backlash in spec an get a deeper pattern but I'm gonna have to make it happen if I ever find time
  #1347
Old 10-29-2014, 05:33 PM
newguy's Avatar
I`ve between 0.003"~ 0.006
Attached Thumbnails My small 96 Blazer build-gears3001.jpg   My small 96 Blazer build-gears3003.jpg
  #1348
Old 10-29-2014, 05:47 PM
rexmburns's Avatar
Super Moderator
Yeah I'll take some out. .003-.012 is acceptable with .005-.008 being ideal so I'll move the carrier over and get the pinion in a bit deeper since I've got a bit of wiggle room with my backlash.
  #1349
Old 10-30-2014, 04:45 AM
Smitty Smithsonite's Avatar
I had a howl when I let off the gas in my Grand Marquis diff once, after swapping a pinion seal - just a few inch-pounds more torque on the pinion nut, and all was well. YMMV since you've had the gears out however. Definitely looks like it could go a couple thou deeper.
  #1350
Old 11-04-2014, 05:15 PM
rexmburns's Avatar
Super Moderator
Got a good bit done on my bumper today. Rear crossmember cut out and gone. Sorry for the crap pics!
Cut the ends off the receiver and shortened it a tad to fit inside the frame rails
Cut what I guess is a reinforcement ring off the receiver it will go back on later.
After a whole lot of measurements and test fits I drilled some holes.
Then I cut out the center for the receiver to slide thru. Now you see why I cut off the ring
And then I did a whole lot that I didn't take pics of and this is where I ended the day.
Just have to do a bit more welding and get some reinforcement built into the frame for when it's bolted on and I will be done till I add some led reverse lights later on. I think it looks a lot better and beefier now.
Attached Thumbnails My small 96 Blazer build-8e3606b0-51bb-444f-be68-a7bb16b47a24_zpsbmiyucuv.jpg   My small 96 Blazer build-da9e9d3c-fe0c-459a-929c-2a837b3d6b34_zpsi8apzd2j.jpg   My small 96 Blazer build-a3a430e9-35c3-47e0-8015-dbe79b327684_zps5ntokuab.jpg   My small 96 Blazer build-0676379b-486d-4655-8f3d-b31363812113_zpstvym4wft.jpg   My small 96 Blazer build-0ea901b4-559c-41ce-aca0-22d2c8ded61d_zpsd64qqdkb.jpg
My small 96 Blazer build-e932122a-20df-4f62-9843-4dc47d03a6b8_zpsc4s4trv5.jpg   My small 96 Blazer build-16e7cefe-3ba1-48fa-9ec1-e6524d6a552f_zpszp18spzk.jpg   My small 96 Blazer build-cef42fd6-0d4b-47c8-8611-73b792981f0a_zpspzi1x110.jpg   My small 96 Blazer build-1ec320d9-05ec-4099-9ef9-19ea61645e6c_zpsap8s02vw.jpg   My small 96 Blazer build-216fb31b-c10f-466b-8ac6-6d4460b05017_zpsaveu0gus.jpg
Quick Reply: My small 96 Blazer build
