1.6 rocker arms
1.6 rocker arms
has any one tryed putting 1.6 roller rocker arms on the 4.3. if so did you notice any differance in power. i did it on a v8 and felt a differance but dont know how it will work on late model v6
Depending on the year, you would have to have the heads machined to accept adjustable drivetrain since you would be going away from stock 1.5 ratio. You wouldn't want a valve to shake hads with a piston - or two.
1.6 rockers
not sure what the guy you talked to is refering to, if you are installing larger diamiter springs you would have to mach. the soring seats an the heads. but i dont know what that would have to do with changing the rockers. mostly i was wondering if any one had done this and checked valve to piston clearence, and wether or not there was any clearence problems with spring bottoming out. thank you
well call comp cams i dont know to much about that chit the guy at wynjammer told me to get a custom grind cam from comp 6:1 roller rockers tip and pivot valve guides and the tec man at comp told me i would have to have the heads machined for the double springs but like i said i dont know chit i figured the guys tellin me what needed done knew what they were talkin about sorry
Ok. Here is the break-down...
Roller rockers are considered "adjustable valvetrain." Vortex 4.3s (and many other newer engines) have non adjustable valvetrain. So to run roller rockers of any ratio, you need to get the heads machined to accept them.
Custom cams- high lift, NOS, blown or towing/rv need to run under different pressures. That being said, the higher the lift, the more substantial the valve spring setup is going to be. To get the spring assemblies to sit on the cylinder head correctly, you have to machine the valve spring seat.
Bottom line, head work is pretty expensive but well worth it!
so the cam i was told to get and roller rockers is 640$ after shipping and the speed shop wants 1400$ to do the head work and cam install do you think that is a reasonable price i cant control the price of parts but do think i should be able to find better price on the machine work and labor
