1999 blazer 4.3
1999 blazer 4.3
Hope someone can help engine turns over a few times then starts sluggishly,but i can tap the gas and it comes to full power, gave it a tune up plugs and everything else, changed the coil,had the ignition module tested and it OK, tested fuel pressure and it in range .doesn't matter if hot or cold.also changed the cold start sensor.at my wits end with this .
kamilkowalski
04-30-2015 08:36 PM
