97 wont start, tried everything I can think of. NEED HELP!!
Old 03-13-2011, 11:06 PM
storm17angel's Avatar
storm17angel is on a distinguished road
Default 97 wont start, tried everything I can think of. NEED HELP!!
Hi, I have a 97 blazer, 2 door, 4wd, 4.3L,
The fuel pump went bad last april, so we replaced it and it worked just fin until the car stopped in december. we've changed the spider injector, fuel pressure regulator, fuel filter, plugs, wires, cap. the car is getting spark just fine and you can hear the pump come on all the way at the front of the car. it is loud. car has not been working for about 4 months now. NEED HELP!!! ANy ideas???
Old 03-13-2011, 11:54 PM
rriddle3's Avatar
If you're getting spark to all the cylinders try working through the steps in 96+ Fuel System Diagnosis and see if it helps you.
Old 03-14-2011, 12:17 AM
LowLife's Avatar
LowLife is on a distinguished road
yea my guess is that the fuel pump is coming on, But not with the right amount of fuel pressure,or your firing order on the plug wires got mixed up some how, or you got a faulty spider injecter setup
Old 03-14-2011, 02:27 PM
We checked the pressure with a pressure gage we rented from autozone, and it is getting no pressure to the fuel rail, could it be something in the electrical system telling the fuel pump not to send the fuel? or something wrong with the lines?
Old 03-14-2011, 03:36 PM
rriddle3's Avatar
To solve the issue you're going to need to work through all the steps in the link I provided above.
Old 03-14-2011, 04:34 PM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
seems like a dumb question but did you install the fuel filter in the right direction?
Old 03-14-2011, 05:37 PM
LowLife's Avatar
Thumbs up
yea for his year blazer there is only 1 way to install it, a theaded line on 1 side of the fuel filter, then a quick release on the other side, i know on my 96 blazer u can indeed install it backwards because both sides of the fuel filter are a threaded line no quick realease clip
trippymg
02-17-2012 08:10 PM
rocker665
10-23-2011 01:55 PM
ekh08
03-23-2009 02:19 PM
Always Something
11-11-2008 07:27 PM
Mr2turbox
01-31-2008 10:28 PM
Quick Reply: 97 wont start, tried everything I can think of. NEED HELP!!
