No heat, tried everything
Old Jan 31, 2008 | 10:10 PM
Mr2turbox's Avatar
Mr2turbox is an unknown quantity at this point
Default No heat, tried everything
Please oh please someone help me. I bought an 83 s10 blazer with an 89 or 90 4.3 in it. Heres the problem, The water pump had the outlet that supplied the heater core plugged off and the heater hoses ran from the block to the core and from the core to the radiator. so i put a new pump on it and supplied the core with water. i then plugged off the hose running to the radiator as i dont know what goes there. bear with me, im new to piston engines. im a rotary guy. so anyways, the core is spewing water from under the engine compartment and i still have no heat. im really angry and want to beat this piece of junk to bits. is the core not under the dash? and one more problem... i had to change my blower fan because it kept blowing fuses, or thats what my mech said. guess what? every 2 days, pop. mech says not to worry, but i am. any advice?? anybody who gives me the correct answer i will give directions to the best 4 wheeling in this state. costs nothing but gas to get here
Old Jan 31, 2008 | 10:19 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Default RE: No heat, tried everything
Blazer that old light it on fire and collect insurance... LOL The last owner obviously knew the heaer core was gonna be a bitch to replace and exp also, so they blocked it off .... I`m sure you were prob never told about the problem??? if ya got from aused car lot ,drive it thru their front window... more than likely the old motor was a 2.8 thats what an ex friend had in his 87 blazer ... Good luck with it.. If ya do burn it ,put the video on youtube LOL
Old Jan 31, 2008 | 10:28 PM
Mr2turbox's Avatar
I got it from some little drug addict that i worked with, and no you are absolutely right, i was told that the problem was the thermostat. he said it was a 160 and i needed a 195. i put a 195 in and thats how i discovered the water pump was blocked
99blazer604
Aug 2, 2011 09:25 PM
MerCiLeSS
Jun 20, 2009 12:44 PM
ekh08
Mar 23, 2009 02:19 PM
Always Something
Nov 11, 2008 07:27 PM
f1yrod
Apr 13, 2008 04:48 PM
