96 Blazer Transmission problem???
Old 03-19-2009, 02:48 PM
strobachyzoo's Avatar
strobachyzoo is on a distinguished road
Default 96 Blazer Transmission problem???
I just bought this 1996 Blazer for $500.00 with 146,000 miles knowing it had a trans issue. (4.3L with 4l60e) But this is a strange issue. First it has no reverse, not like it has neutral for reverse, but like the vehicle will not move and can not even be pushed or pulled in reverse... Second when in neutral it moves forward... In low1 and drive it is sluggish at first... Other gears seem to work including a good solid feeling 4th. The fluid was low and smells a little burnt. I topped it off before test driving it. The SES light is flashing but the only code I retrieved was for a #1 cylinder misfire. It has new plugs, wires, and distributor cap.(seems like a plugged injector tip) From what I've been able to find out from a friend who works at a dealership the PCM and trans were replaced on this vehicle under warranty in 2001.
Any ideas?
Thanks,
Kurt
Old 03-19-2009, 03:53 PM
I would start by adjusting the shift linkage. Sounds like it is out of adjustment and actually in park when you have the selector in reverse and in 2nd when in L1. Some trucks will actually start out in 2nd gear when in L2, skipping 1st entirely.
About your cylinder 1 misfire, if you suspect an injector problem, you could do a fuel pressure test and activate that injector while monitoring the pressure drop. I do not know the requirement off the top of my head, but there is a number somewhere for how much the pressure should drop given a certain length of time the injector is open. First though, the pressure has to remain stable before you can perform the test...
Old 03-19-2009, 05:47 PM
Ok, I disconnected the shift cable with the trans in neutral and manually put the shift shaft through it's range of positions then brought it back to the third position (Neutral) then snapped the cable link back on everything still lines up the same... It starts in "N" and "P" and the reverse lights come on in "R". But now something has changed... In low1 the transmission locks up even if the vehicle was rolling forward it feels as if the brakes are applied. Like the trans is in two gears at once, the same feeling it has in reverse... And the trans is getting warm very fast.
And on the injector issue this engine has the spider. (luckily with replacable tips
Old 03-19-2009, 05:54 PM
It sounds like you need to get it to a shop for the trans issue.
As far as the injector goes, you could replace the injector/line/nozzle assembly for that one cylinder if you want, but the SCFI fuel systems being as they are, you are likely to have problems on another injector/nozzle assembly sometime in the future. The poppet nozzles at the end of the line love to stick and/or get clogged. The electronic injectors (in the central pack) do not typically have any problems. But you cannot just replace the tip (poppet).
Old 03-20-2009, 08:37 AM
Default Transmission diagnosis (Long)
I found this thread on the Impalla SS board. #28 pretty much describes the issue it's having except for the "new" issue with low1. If the previous owner didn't drive it too much this way I may be able to fix it with a different valve body. (If the issue is a cracked forward piston that is sticking/gouging it's bore in the valve body) I can hope can't I?
Anyway an expensive transmission shop trip is not an option. Worst case I have to put another trans in it... I've got a spare in a parts blazer behind the barn.
I've just got to reassemble and paint my pickup before i can get the blazer in the barn for any major work. And the weather isn't going to cooperate much this week, looks like rain and tenps in the 50's for the next week I need at least 60's to paint...
http://www.impalassforum.com/vBullet...ad.php?t=95721
Thanks to sherlock9c1
Last updated: 6/9/2007
Before guessing at transmission problems, check the fluid level (car warmed up, engine running in Park on level ground) and have the PCM scanned for trouble codes FIRST. This guide is meant for problems that do not show up as PCM codes (like shift A&B solenoid failures, for example).
NOTE:The transmission is on the same fuse as the MAF, O2 sensors and at least one other sensor - if an O2 shorts out, it will blow the fuse and the trans will go into limp-home mode. Be sure the trans has power and the fuse is not blown before doing anything else.
Also note that many problems that show up as transmission issues are actually PCM or electrical, and may be external to the transmission. Try a different PCM, and check for chafing where the cables come out of the PCM and touch the LF fenderwell.
ALL ELECTRICAL PROBLEMS ON THE B/D-BODY 4L60E CAN BE FIXED WITHOUT REMOVING THE TRANSMISSION.
Secondly, put a line pressure gauge ($55 shipped on Ebay, or visit a local trans shop) on the pressure test port and go for a drive to verify proper line pressure. Base pressure at idle in P,N,OD should be around 70psi and around 140psi in R. Max line pressure should be at least 190psi at WOT in 1st or 2nd, 225psi is optimum. If base pressure is low, trans or pump is worn out. If max pressure is low, check EPC solenoid. If reverse is slow to engage, and line pressure does not come up to at least 130psi in reverse, replace the boost valve with a Transgo 0.500" boost valve (easy fix in pan).
Beware of coolant contamination - coolant will cause clutchpacks to delaminate and thus cost you a rebuild! Trans fluid eats radiator hoses! If you find any sign of cross contamination, fix the problem and thoroughly flush both systems IMMEDIATELY.
What is "limp-home mode" ? This is a fault mode in which the transmission either loses electrical power or the PCM deactivates all of the electronics. The transmission will default to max line pressure. The driver will have Reverse and 3rd, with manual 2nd available by putting the gearshift in 2 or 1 (doesn't matter). 1st, 4th, and TCC lockup will not be available. It will not hurt the car to drive it like this for short periods, but use manual 2nd to get the car moving, and be aware that the trans will generate more heat than normal while operating in limp-home mode due to increased torque converter slippage during 2nd gear starts and no lockup in 3rd gear.
If you need 4L60E hard parts or electronics, send me a PM as I have a bunch available.
R&R = Remove & Repair (or Rebuild) = Transmission must be removed to fix the problem and may have to be rebuilt or replaced.
Common failures on 4L60E, symptom -> cause -> any possible repair:
1. Slow, slipping or no reverse: “lo-reverse” clutches are worn out, fluid leak in the reverse apply circuit, or broken sunshell. It is possible to remedy a fluid problem by removing the checkball from its cage in the case in the rear of the trans may help (must remove valvebody), or adding a high-viscosity additive such as Lucas Transmission additive or other seal restorer product. May also have worn boost valve (can replace in the pan).
2. 1-2 shift does not happen at WOT until you let off the gas: Best case: try replacing the TPS. Middle case: leak in the 2nd gear apply circuit (servo assembly or 1-2 accumulator). Doublecheck by using the pressure gauge and watch for a big drop when the PCM commands 2nd gear. Worst case: poor line pressure rise (see below).
3. 1-2 Shift shudder at WOT; delayed or abnormal 1-2 shift; There's a problem ONLY on the 1-2 shift: 1-2 accumulator piston cracked or stuck cocked in the bore. Check the yellow spring inside the accum housing for breakage. Also, if the accumulator housing walls are scored, the housing must be replaced. Easy fix in the pan.
4. 1-2 shift is delayed and harsh, may not shift into OD: Check TPS for smooth and linear electrical response over the entire range of motion. If not, replace.
5. Trans does not upshift out of first, speedometer reads zero at all times: VSS failure. Easy fix on rear of transmission, but xmember must come out to access VSS.
6. No 3rd or 4th gear: “3-4” clutches are worn out. R&R. The car is safe to drive (in 2) until you can get it fixed.
7. Sudden grinding noise with no prior warning primarily in 2nd gear, behavior in reverse may be abnormal; sunshell is fractured. R&R. Try not to run or drive the car or further damage could result.
8. 1st and 3rd only, no 2,4 or R; sunshell is fractured or splines are sheared off. R&R. Try not to run or drive the car or further damage could result.
9. No 2nd or 4th gear. 2-4 band is slipping. Servo seals may be damaged (can be fixed without removing trans. Otherwise, 2-4 band is worn out. R&R.
10. Trans shifts into gear harshly, car feels sluggish off the line, No 1st, 4th or TCC lockup available, Manual 2nd, 3rd and Reverse are only available gears, CEL is on: Transmision is either in limp-home mode or has lost electrical power. If there are lots of error codes in the PCM, check the underhood fuse that powers the transmission, and if it pops again, look for a short in that circuit like an O2 sensor harness touching exhaust. Otherwise, check PCM codes for a particular fault in the transmission causing the PCM to put it in limp-home mode.
11. No 1st or 4th available; trans shifts 2nd to 3rd by itself in D or OD and locks the converter : ShiftA solenoid failed. Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
12. Car goes into gear but feels very sluggish like the brakes are dragging, but it will roll easily (starts out in 4th gear), you manually shift to 2 to get it moving, once it's moving you put it back in OD and the car shifts 3rd to 4th on its own and locks the converter at the appropriate time: ShiftB solenoid failed: Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
13. No TCC lockup: Brake pedal switches improperly adjusted (always on), TCC solenoid failed (easy fix in the pan), TCC clutch worn out (must remove trans and replace TC).
14. TCC always locked: TCC apply solenoid circuit shorted to ground, TCC solenoid blockage (easy fix in pan), or TC broken (must remove trans and replace TC).
15. Horrible noise in 4th and feels like the brakes are on: overrun clutches are applying due to a cracked or leaking forward piston. Overrun clutches will be worn out after 30 seconds of this behavior. Car can be safely driven in D. R&R.
16. Soft shifting, gradual performance degradation: Poor line pressure rise due to leaking boost valve, clogged EPC filter screen, failing EPC solenoid, or worst case: leaky seals throughout. Transgo HD2-C kit fixes first two without removing trans. Seal restorer may fix last problem, but probably R&R. Also try a transmission flush with BG brand products (Firestone stocks it).
17. No forward movement in OD or D, but L2, L1 and R work: Forward sprag is broken. R&R. Try not to run or drive the car or further damage could result.
18. Extremely harsh shifts from P or N, normal shifts at WOT: EPC (Electronic Pressure Control) solenoid failed. Easy fix in pan. Fix as soon as possible or hard parts will eventually break.
19. Loud bang, grinding sound, loss of all gears, and a binding driveshaft: snapped output shaft. Try to wiggle driveshaft - if more than 0.020" play, that's the sign. R&R.
20. Trans seems noisy when moving in 1st and Reverse, noise goes away instantly if you shift to N or the trans goes into 3rd gear: Reaction planetary is worn out due to high miles or insufficient lubrication. Not a critical failure, but not a good sign either. R&R sooner rather than later.
21. No movement in any gear: pump failure, or total loss of fluid. R&R, or refill pan and find the leak. If out of fluid, avoid running the engine until the trans is refilled to avoid pump damage. To check for pump failure, check fluid level with the engine off, then start the engine and recheck fluid level. If level does not go down when engine is running, the pump is broken.
22. Transmission does not shift automatically, only manually. Swap in a known-good PCM, check wiring, check other sensors such as VSS and TPS.
23. 3rd gear starts, can manually shift through all gears. When car has been turned off for a bit, then back on it will run normally.: VSS dropoff w/ Hi-stall converter. The rpms are too high, but VSS is showing no movement. Happens after a tire burning take-off. Doesn't store a code, will not throw a CEL (I've heard that it will store a code if it happens 3 or more times). Cure: Reprogram PCM for VSS dropoff -- PCMforLess knows about it.
24. Fluid leak out of the front of trans where the converter connects; partial or full loss of movement: Front pump bushing walked out. R&R. May have to replace converter also if hub is scored. Note that a leaking front seal usually means the bushing is walking out (i.e. call your local trans shop and schedule an appt.).
25. Torque converter shudder in 4th while lockup is engaged; problem goes away when the brake pedal is pressed slightly to unlock converter. Have a shop verify line pressure, and provided no valves in the TCC hydraulic circuit are worn, replace the torque converter. Also, Lubegard Shudder Fix will at least fix this for awhile. Or try a transmission flush by a shop that uses BG brand products.
26. Shift suddenly become very hard. When going from park to either reverse or drive it slams into gear. 1-2 and 2-3 shifts are also harsh. All gears seems to work. Problem may be intermittent: Check TPS for smooth electrical response. If the response is jumpy or erratic at all, replace TPS.
27. All fluid pumped out through the vent tube: Plugged cooler line. Flush the transmission cooler and cooler lines. Also could be overfiled transmission.
28. Car acts like it's in OD in neutral, car is locked stationary in R, engine feels loaded in P, all four forward positions work fine: R&R: Internal crossleak feeding the forward clutches all the time. Most likely a cracked input housing, or cracked forward piston means forward clutches are fused together. Car can safely be driven gently in forward gears until the repair.
29. Needle bearings in the pan, first gear and/or reverse may be noisy: Either a torrington bearing or a planetary bearing is on its way out. Trans will eventually die a loud, catastrophic death. Cheaper to rebuild now (saves further damage to hard parts), but requires R&R. It is drivable until it breaks.
30. 1-2 or 2-3 shift is slow/soft above part throttle: Trans is on its way out. R&R.
Old 06-18-2009, 09:21 PM
05mccmsu is on a distinguished road
Default 96 transmission cooler
How is the best way to learn how to unplug the cooler on a 96 transmission cooler
GloryImSaved
07-17-2009 09:05 PM
sfesenko
12-12-2008 10:03 AM
dantheislandman
04-08-2008 07:15 AM
dantheislandman
04-06-2008 10:30 AM
BigJoeFord
06-05-2007 01:31 PM
Quick Reply: 96 Blazer Transmission problem???
