98 blazer 4x4 transmission repair or replace?
Old 02-19-2012, 06:58 PM
JamesHotWire's Avatar
JamesHotWire is on a distinguished road
Default 98 blazer 4x4 transmission repair or replace?
Hello all, my first post here, I,ve been scanning though the forums havent found anything related to my issue, though likely it's been covered. If so some links would be much appreciated.
Ok so I bought a 98 blazer from a fellow maintenance worker. He was fuming mad at his truck as was planning on scrapping it. So I gave him $300 for it and towed it back to my house today. He claims he was driving highway speed and that the transmission just locked up and threw him into the dash. Prior to that he said it was shifting fine, only had a small leak that required a monthly fluid top off. The truck has right at 200k miles and other than the fact that the is now no forward or reverse seems to be a solid truck. The fluid is in range on the dipstick, normal in color and smell, and no metal flakes that I could see. I did hear an occasional clang from under the bellhousing so definitely something is broke in there, also when I pulled the dipstick the was a slurping sound coming from the filler tube. And that's all I know at this point, as I haven't got into it any further yet. I have located a used transmission, but would like to be sure it's not something I can fix on this one first. Any input on the matter will be greatly appreciated.
Old 02-21-2012, 10:26 PM
jeffthenail's Avatar
jeffthenail is on a distinguished road
Suggest dropping of the Trans oil pan to see what may be obvious. Next step is to remove the trans and get a manual to possibly disassemble for repair. If the other unit is reputed to be good, put it in. chances are you can't rebuild the one you have for $300.
Good luck!
Fred Nutcase
06-30-2014 11:09 AM
rockp2
12-11-2012 08:20 PM
96blazer191k
06-22-2011 12:30 AM
TomSawyer
02-15-2010 02:11 PM
Shadow1
05-03-2008 03:30 PM
Quick Reply: 98 blazer 4x4 transmission repair or replace?
