strange noise
Old 03-17-2011, 04:41 PM
Dave455's Avatar
Dave455 is on a distinguished road
Default strange noise
I have a 2000 Blazer LT 4.6 4wd and recently have been hearing a noise like a rattling at speeds from 30-50mph. It is not consistant with the speed more variable and not when I hit bumps or rough roads.Trying to locate this has been frustrating. One thing I had noticed today is the front drive shaft moves slightly (less than 1/8 in.) both laterly and horizontly and makes a noise. My question is this movement normal or is this the cause of my noise problem. How difficult is it to replace and does anyone have a source to get a replacement. Thanks in advance for any help.. Dave
Old 03-17-2011, 05:16 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
Are you talking about the drive shaft that comes from the transfer case to the front end or are you talking about the cv axle shaft that goes from the front end to the wheel ?
Old 03-18-2011, 07:10 AM
Dave455's Avatar
It's the drive shaft going from the transfer case to the front end. The vehicle has 153k miles on it and I only use the 4wd a handful of time in the winter just wondering how it could go bad
Old 03-18-2011, 05:49 PM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
The U-joints may be bad, they aren't expensive and not too terribly difficult to replace.
Lilcheef
07-13-2007 08:14 PM
aced411
17
07-11-2007 03:10 PM
Hanr3
02-24-2007 01:50 AM
ckirv
12-07-2006 03:17 PM
blazergirl15
07-04-2005 07:35 AM
Quick Reply: strange noise
