Cap and Rotor replacement on 97 Blazer
The new rotor should have come with new screws and thread locker already on them. If the screws are stripped, replace them. If the distributor is stripped, you can try to repair the existing threads, tap new threads, or replace the distributor. The rotor is keyed on the under side so it can only be installed one way.
If you need to replace it:
GM CHEVY V-6 VORTEC DISTRIBUTOR ALUMINUM BODY
er0ck273
08-24-2015 12:22 PM
dirtbagger
02-25-2009 07:51 AM
