intermitent miss
Old 01-01-2016, 02:49 PM
10-78 edac's Avatar
10-78 edac is on a distinguished road
Default intermitent miss
I can't find the thread to check if I should buy a new spyder. I have an intermittent miss and it's not throwing a code. Seems to go away when I'm accelerating. Delco plugs, cap, and rotor look good. 60+ psi and holding on fuel port by dist. Wife's car got totaled on Christmas. Need help to get her running smooth by Tuesday.
Old 01-01-2016, 04:54 PM
Checking fuel pressure at the service port will give you the lower of regulated pressure, or fuel pump maximum output, not a good test by itself. Here is the link: https://blazerforum.com/forum/2nd-ge...eakdown-88305/
Old 01-01-2016, 04:59 PM
10-78 edac's Avatar
Thank you for your reply.
Old 01-01-2016, 08:57 PM
10-78 edac's Avatar
All fuel pressures checked out okay. Cap screw on the fire wall side of the distributor was loose. All the plugs looked okay, regaped to .045. Found and repaired a rotten vacuum line, gave it an oil change, and it seems to be running smooth. While I was under her I noticed that I will be changing the remote oil filter, and oil cooler lines soon, but that will be another day.
Thanks again for the link to the proper trouble shooting. Glad I didn't need to pull the intake plenum apart.
Old 01-01-2016, 09:46 PM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
I thought 1st generations had an .035 gap and 2nd had an .060 gap....?
Old 01-02-2016, 12:14 PM
10-78 edac's Avatar
Read that the .060 gap was tough on ignition componets, reviewed with trusted 35 year GM mechanic. Even GM went back to the smaller gap.
Spark plug gap - 1999-2006 & 2007-2013 Chevrolet Silverado & GMC Sierra 1500 - GM-Trucks.com
Some of the information I found on the topic.
Old 01-02-2016, 12:25 PM
CWBDDSPC's Avatar
Interesting
Old 01-02-2016, 07:28 PM
Yup, interesting, but the TSB does not include the 4.3L engine.
Old 02-06-2016, 08:09 PM
10-78 edac's Avatar
Ended up changing the cap and rotor. running smooth again.
ussexplorer
09-27-2013 03:38 PM
Tbanditt
02-18-2010 02:46 PM
danyboy
10-21-2009 05:43 AM
purpleblazer95
06-26-2009 08:36 PM
chapy
02-27-2009 05:39 PM
Quick Reply: intermitent miss
