fuel pump changed and won't start
Old 01-07-2012, 08:57 PM
stoploss10's Avatar
stoploss10 is on a distinguished road
Default fuel pump changed and won't start
Ok first I have a 1997 S10 Blazer LS 4.3 Vortec, problem started when my truck shut off while driving down the road tried to start it but pump wouldn't even make a sound. I changed out fuel pump and it runs like a dream but the engine will not start, sprayed ether in starts for about a second n then turns off. Disconnected the fuel line from the input of the Spider Assembly and has plenty of pressure though a pressure test has not been done. What r the chances that all 6 of the injectors could be clogged at once from the new pump? Any help would be great Im about to just put a rag in the tank and light a match.
Old 01-07-2012, 09:48 PM
xgiovannix12's Avatar
do you have spark?
try to diagnose the fuel system before you guess again
96+ Fuel System Diagnosis - Blazer Forum - Chevy Blazer Forums
guessing can be expensive
what brand pump did you put
Old 01-07-2012, 11:31 PM
Gale's Avatar
Gale is an unknown quantity at this point
We had a fuel pump stop working today about 5 miles into a test drive after replacing the engine. Beating on the tank got it to run for a second then it stopped.
Looked under the nose of the S10 and found the plug to the crankshaft sensor had not seated well and when hitting about 3500 RPM in second gear on take off it died like a rock.
The fuel pump was fine after the connector was properly seated.
Sometimes one can have two problems at the same time and that is a pain.
Jordan1840
08-24-2014 10:20 PM
mbaquet1
10-16-2012 07:38 AM
stanger_missle
07-04-2011 06:13 PM
bassman
01-11-2011 04:35 PM
mkemu80
01-29-2010 12:48 PM
Quick Reply: fuel pump changed and won't start
