screws for Intake Rail Hold Down?????????
Old 03-28-2015, 08:38 PM
kruelblazer's Avatar
kruelblazer is on a distinguished road
Default screws for Intake Rail Hold Down?????????
So recently i been smelling alot of gas the other day it started to puddle up on top of the engine, apon further inspection i found that were the two gas lines go into the top of the engine theres a hold down, Later i was told its the Intake Rail Hold Down, i tried to tighten the screws but they were over tightened by the last owner and had been broke. I have located the part in a junk yard not to far from me, but they wont sell me the screws its part of the intake they say and want to sell me the whole intake. Does anyone know were i could get these screws?
Attached Thumbnails screws for Intake Rail Hold Down?????????-20150328_210940.jpg
Old 03-28-2015, 09:27 PM
Brian K. Balzer's Avatar
Brian K. Balzer is on a distinguished road
Default Not sure.
However, the first question is going to be if it is for the 2000 Chevrolet Blazer or something else. You might try searching Ebay though.
Old 03-28-2015, 09:30 PM
dont know the name of the screw, and dealer dont have it and i cant find it on ebay thanks
Old 03-29-2015, 09:12 PM
The screws are part of the fuel injector assembly. If they were over tightened, the holes in the injector assembly are likely stripped. If that's the case, you'll need a new one.
Old 03-29-2015, 09:28 PM
Default Good point
I'm not real familiar with them myself. On the off chance that the screws are designed to be softer than the threads of the holes they screw into and you're lucky enough that the holes are good and Only the screws are stripped you might Google search for specialty fastener places near you. Then take one of the screws in with you for a comparison to see if they have them. I had to do that once for a specialty shanked bolt.
Old 03-29-2015, 09:31 PM
The injector housing is plastic
Who ever had it apart probably didn't get the washers, o rings and retainers installed in the correct order, and it leaked, so they tried cranking the screws down.
Old 03-29-2015, 10:02 PM
Default Well then...
it seems someone is the victim of previous mechanic syndrome.
ABSLT
08-31-2012 11:46 PM
kgkern01
06-21-2011 03:55 PM
bigdaddykane93
07-18-2010 02:46 PM
blkblazer
08-30-2009 01:59 PM
oldchevron62
11-24-2006 03:05 AM
Quick Reply: screws for Intake Rail Hold Down?????????
